Thread: PH test bright red?? high or low?
    Jun 2011
    South Shore - Massachusetts
    39
    Hi Folks
    My ph test has been showing a clearish red for a while now, unlike any color on the test tube. I added about 12 liq oz of 20/31% muriatic acid 2 days ago, today with a FC reading of 8, CYA about 60, ph test shows bright red, can you tell me if this is high or low ph, again nothing on comparable test tube matching this color.
    Thanks
    Ed
    Massachusetts
    "Keyhole" 20 X 40, approx. 24,000 gals., Salt Water, vinyl liner, Goldline T-Cell 15 SWG, Aqua Plus Controls, Hayward 1 1/2 hp Super Pump, Hayward Gas Heater, Hayward 4 Cartridge Filter, Solid Safety Cover with Center mesh panels, AquaBot Remote Control Cleaner
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: PH test bright red?? high or low?
    It depends on your test kit, but think of it this way. If your colors get more red as the number goes up, then you are over the top number. What we recommend is that you pretend you are at the top number, put that into Pool Math and add MA as directed. Test in 1/2 an hour and continue to adjust until you get to the pH you are targeting.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
