Thread: Adding a sand filter
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    I currently have an intex swg system with the catridge filter built in. I just purchased an intex sand filter with pump. I was wondering if it will be easy to add the sand filter and stop using the cartridge filter....I havent been able to find any instructions on this site or Youtube.
    1200gal intex 10' x 30" round metal frame vinyl above ground pool, intex swg with 12"sand filter, tf-100 test kit
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Re: Adding a sand filter
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    That is what I was thinking....just wondering when I turn on my swg if the pump will run too?
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    well, like I suggested to that poster, I have the pump/ sand filter & a separate SWG. My SWG has a flow switch that gives an error if the pump is off.No reason you can't try it.It won't hurt anything and the readout will tell you if it is working!
