Thread: Liner leak between layers
    May 2016
    Omaha, NE
    11
    Ok, need some advice. After completing a rather lengthy SLAM to bring pool back to sparkly brilliance, we discovered a small leak. It was discovered after a long vacuum session, standing water between a couple of legs. Feeling completely defeated. Was ready to throw in the towel. While waiting for chlorine to burn off the past couple of days, we did little maintenance other than chemicals & the standing water dried up. Gone! No more leak! This morning we tested chlorine level & it is ready for swimming!! Hooray, happy family😄🐠🐬! Vacuum pool & water appears in the same spot! What the heck!!! We have two intake valves and 1 return. It seems the leak is coming from between the layers on the valve we close to vacuum. Tried a little food color in the area but no visible "pull" on either valve. Does anyone have experience with anything similar to this? We have Andersen flexible sealer but I have no idea where to consider applying it. It feels like when the valve is sealed with the little black cap, the leak occurs. Logic tells me to not seal that valve but would also like to solve the problem.
    Heather Vondra
    14x42 Intex Ultra Frame, above ground, Intex filtration, Krystal Clear Sand Filter 2800 GPH & Saltwater System CG-28667
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liner leak between layers
    Could you post a picture? Most of the time I would recommend replacing the valve but I am not sure what you are seeing
    May 2016
    Omaha, NE
    11
    The one on the right causes the issue when plugged. We vacuumed yesterday plugging the left and using the right as suction for the vacuum, no issues or leaks what so ever! Strange. If this works through the season I will deal with it once we can drain below and go from there.
    Heather Vondra
    Jul 2007
    Hillsborough, NC
    525
    if it only leaks when plugged, I would use the right for suction to vacuum and deal with it at the end of the season.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
