Thread: Eco Saver Solar Heater Pipe Size
    Jun 2016
    Reading MA
    9
    Hi,
    I recently purchased an EcoSaver 20 ft solar heating system to run off my filter pump system. When I attach the 1.5" flexible PVC hose to the male and female elbow fitting it is very loose. I could follow the instructions and secure it with hose clamps but this seems week to me. Does anyone have this solar heater and have any suggestions for a better fit?
    Thanks
    Justin
    20'X40' Inground 30,000 gallons. Vinyl Liner with Hayward EC65 DE filter.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Eco Saver Solar Heater Pipe Size
    Hose clamps are often used on solar panels. Are the fittings both 1.5"?
    Mark
    Jun 2016
    Reading MA
    9
    The fittings were too loose for the 1.5" and they were too big for the 1.25" flexible pvc. Do they make a flexible pvc that inbetween 1.25" and 1.5"?
    I'm fine with using hose clamps but they fittings were too loose in the 1.5". I can see it blowing out.
    Jun 2016
    Reading MA
    9
    After three trips to three different pool stores I found what I was looking for. Incase someone is reading this in the future, unscrew the fitting that ecosaver gives you, throw it in the trash and screw in the new adapter that then runs into a standard 1.5" flexible PVC.
