Page 1 of 14 123411 ... LastLast
Results 1 to 20 of 277
Thread: New Pool IG - Inland Empire, CA - Pool finished, end pix soon!
    Jul 2016
    Rancho Cucamonga, CA
    231
    Hello all!
    I stumbled upon your forum during a late night search for pool information and liked all the photo updates etc. so much that I decided to partake in the fun and create my own thread for our project!
    Our dig begins next TUESDAY 7/12! We had planned the pool design years ago and have known pretty well what we wanted in our backyard. After several years of other things going on, light naggings from the HOA *ugh* about our unfinished backyard, and cement work throughout the entire property except for the backyard, it is finally time! We had a design drawn out by hand and the pool company we eventually went with took it and turned it into a 3D render... and while we think they spent less than 5 minutes doing it and ignoring a lot of the things we've said, I took their drawing and altered it quite a bit in Adobe Illustrator to represent what we're looking for (design wise).
    - From the backdoor is a balcony covered rectangle and from there will be a step down to pool level (0).
    - The pool is half peanut shaped with a back wall ~2ft high. (Pool- 15x31', Spa- 7x9')
    - On the east side (left) there are 6 steps up to a raised patio (+36) and the spa will be one raised step (a ring of sorts) above that (+42).
    - On the back side of the spa is a 'jumping rock' into the deep end of the pool. We wanted a slide, but were told not to for various reasons so it became a rocky ledge...
    - On the opposite end of the pool from the spa are two steps down (-12) and that side of the pool will be a 12" wall from the eventual cement patio.
    - In the pool are the 3 steps down with the second step leading to a baja reef that is large enough for 2-3 people to lay out on with their backs to the coping. In the deep end is a seat (also an exit point), and in the middle is a swim out bench that will have two 12" waterfalls pouring onto it (one on each side). Last but not least, the spa will pour into the pool.
    - Last but not least the equipment is on the west wall and will eventually be enclosed. The PB stated it couldn't be against a perimeter wall but we own the next ~6ft on the other side all the way to the sidewalk and it's not an issue.
    SO, here's an image to look at, and I'll get some photos of the dirt before they start digging on Tuesday. We've sketched out the pool in the yard ourselves to visualize and already have several materials in mind so I'll show you those as well.
    Cheers!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Pool- Inland Empire, CA
    Welcome to TFP
    That looks great, did they give you an equipment list, post it up.. some new builders have been recommending things you don't need and we can let you know
    Jul 2016
    231
    OK! Time for some equipment info and some pre 7-11-16 images!
    Per our PB contract, the equipment is as follows-
    - Two recirculation suction lines (one in spa one in pool)
    - HP Pentair Whisper Flow pump and motor (I think this is what has been upgraded to an "Intelliflo 8 b y160, 4-to-8 speed with 3 inch suction line from pump to spa (adds more jets to the spa)") (the old man wanted more jets in our spa (7'x9'))
    - Pentair 320 Clean and Clear capacity filter
    - (Upgraded) to 400,000 BTU energy stackless heater (the old man wanted to heat the spa very fast)
    - Furnish automatic color rotating lights (we've downgraded these to non-LED standard white lights... any reason to keep them the fancy LED ones?)
    Some photos of the yard (I'm using photobucket, that's best I assume?)-
    This is the yard getting the treatment. We got palms a while ago and have kept them in boxes so they can acclimate, they've done ok but have honestly been a bit abused. They'll be MUCH happier once in a nice moist planter. Of note, the flagstone (and the cement it's sitting on) has been removed and the balcony covered patio will be a step down to the yard/pool level.
    Here is an aerial from the balcony looking to the West. This side will be left mostly as is, it will eventually be a BBQ/pizza oven setup, a spot of grass, and a table/chair area with some sort of pergola or structure. That will happen after the pool, so, later on. The main drainage of the property goes out under the wall where the rock is against it. This drainage pipe is massive and wraps around the entire property and is what all the drains will be tied into. The digging access tomorrow is coming through this wall right on the right edge of the photo (where the wheel barrel is (was)).
    Looking East, this is where most of the action will be. You can see the minor slope against the East wall which is what led to the concept of the spa being raised along with the patio up there. Nice views of the mountains down the side yard from there.
    Here's the main attraction. We drew this from the images and measurements we had to get a better understanding. There's more drawn atm and I'll get a picture of that soon (before they dig tomorrow!). I'm ripping out the cactus by the rocks but they'll have to move the rocks with the digger, I can't move those things by myself!
    Last but not least this is me testing out the location (and size needed) of the baja reef. Also visible is the outline of where the two steps (check the first post) that are on the West side stepping down to the future patio/sitting area. Also please note Benya, my cat, he will likely be present in many photos as he'll be inspecting the work as we go. He is already not happy I've been doing little things here and there to his yard.
    Cheers!
    Jul 2016
    231
    Re: New Pool - Inland Empire, CA - Dig tomorrow!
    For what it's worth, here is the first of my overhead shots I'll be taking throughout the build-
    Note we have some planter walls drawn out and more importantly the underwater features (steps, seats, and baja reef). Also a few of the stones we're thinking on selecting (I'll show them up close later).
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Hi Benya! You will make a good snoop-avisor! Just watch out for the big machines!
    So neat to see it all drawn out. This will be fun to watch! THANKS for letting up come along to help you spend your money.
    Have you been reading many build threads? If so you know what I am going to say.........if at all possible you need to be there tomorrow for the dig. IF, wait WHEN they have any questions or concerns you want to be the one to tell them what you want done. If you cannot be there give one of them your phone number and have them share pics with you if needed.
    Kim
    Jul 2016
    231
    We have the advantage due a variety of reasons to be home (multiple people) during the ENTIRE project. SO, we will certainly be keeping an eye on things hehe...
    Jul 2016
    231
    They're outside digging right now! I'll have some pix around lunch time (I'm not one of you 'fancy' phone owners, so I have to transfer the photos from the camera chip).
    Jul 2016
    231
    Re: New Pool - Inland Empire, CA - Dig day!!
    SO! Here's the events from this morning!
    After some initial sketching on the ground (we were close with our paint, things shifted ~1ft or so) people got to work!
    Break the dam, release the river! (Lord of the Rings reference). Wall came down within due time and has been hauled away (we saved a few bricks and all the caps for rebuilding matching).
    First the small slope was leveled out a bit. The stairs to the elevated patio and part of the spa will be where the bobcat is.
    Then they got to leveling the yard and lowering it. The pool will be at -6" from the back door patio so they had to lower the yard a bit to get the forms in.
    Jackhammering into the dirt/rock to put the form posts in. Here in SoCal against the hills we have to do that. Current rumors as of lunch is that the bobcat is not able to dig the pool (they should've known this beforehand)... we'll see how the convo goes with the boss... they may be bringing a ditch witch in? (I wasn't part of the convo).
    I'm not joking when I say that it takes me 2 days to dig a hole to plant a shrub hehe...
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Congratulations!!! It's dig day (maybe). Your ground sounds a lot like our central Texas (and some other parts) with bedrock right below the top. Sometimes, the biggest expense is the excavation. That old rock can slow things down, but once you get through it, progress will pick up.
    Great rendering and pool design! I can tell you guys have put in exactly what you want and where - that's fun. I love the lines and different elevations of the deck. Lots of interest points going on.
    As soon as possible, get started on building your signature information. You can look at mine and many others for ideas. The more specific you can be the better. As your thread grows in number of pages, it gets harder for a reader to search back for information they may need to answer questions. And when people see something in your build, you won't have to answer the same question over and over - like, "Love your water color, what finish and plaster color did you use?" or, "How long, wide, and deep is your pool?"
    As you get more choices made, you can add to or edit what's already in your signature.
    I'm looking forward to more of those great pictures! Fingers crossed for an easier than expected dig!
    Suz
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jul 2016
    231
    We live on a huge alluvial fan, so no bedrock, but just tons of cobbles, boulders, and crappy soil. I'll post more tonight, but they've switched out for the jackhammer attachment on the bobcat and are plowing away at it. They've already pulled out a couple of ~2ft boulder and only down ~1-2ft hehe.
    I'll work on that signature, in the meantime my pool equipment info can be found here (post #3)- New Pool - Inland Empire, CA - Dig day!!
    Jul 2016
    OC/CA
    2
    Congrats! I'm working on the plans for mine so for sure I am going to be watching this one
    Jul 2016
    231
    Diggers left at 4:30, dropped off the last load (4 today), came back to tidy some tools, and took off. It looks like a pool already! You guys say you like photos so don't worry, I'll be adding TONS.
    This is the laser station and unit they carry around to determine elevation of the pool forms. It was interesting to watch him walk around the yard and hold the stick up and down to determine the level the mold (and ground) should be at. I do the opposite sort of I guess for surveying purposes (geologist here).
    Here's the big gun they brought out on the bobcat to counter the rocks. They've been doing pretty well with this technique of breaking apart the ground/rock with the jackhammer and then scooping it out. They think they can finish the job with this, though if they encounter a large enough boulder, it'll be interesting...
    Here was their progress with the jackhammer breaking up the top couple of feet of material to be dug out.
    Here is day 1's progress pic, taken at 3:30p every day. It should correspond pretty close with post #4 up above.
    Last but not least, once all the work was done, we let the cats out to snoop around. Benya inspected the hole and decided to roll around in the fresh dirt.
    Cheers!
    Apr 2015
    Houston, Texas
    3,217
    Hey! Do you know anyone building a pool who needs boulders for a weeping wall, grotto, or such??? You could cut a deal!!!
    I see one cat. How many are in the picture? I'll do a 'find CAT' game in your last photo!
    Jul 2016
    231
    Only one cat in that photo. The other one that went out is 'One Ear' (a fixed feral cat that adopted 'us'). She was sitting on the side near the patio in awe at what has happened. I'll try to grab her in some future photos (they're a team aka she follows him around and loves him to pieces). Did I do the signature right?
    Pool-15x31', Spa-7x9', depth 3.5-6', HP Pentair Whisper Flow pump/motor, Intelliflo 8-160, 4-to-8 speed, Pentair 320 Clean and Clear capacity filter (upgraded to 400,000BTU stackless heater). Stacked stone- Autumn Rose Classic, tile- Ridgeline Blue Slate, coping- Turning Leaf Quartzite. Start date 7/12/16! Progress thread
    Apr 2015
    Houston, Texas
    3,217
    My son and I are cat people - love cats. I also love dogs, but they always look at me with those sad puppy-dog eyes. Then I feel guilty, and I'm not even sure why!!! My granddog, Willie, is in my avatar. I love him to pieces. As a grandma, it's great to play with him and have him around. And..... it will be much quieter and nice when he leaves after this 3 month visit! Lol!!
    I look forward to seeing a better shot of One Ear and Benya!
    Good job on your signature! Thanks for humoring me. Do ya'll have any idea what you want for your pool finish and color? See, I'm already too lazy to go up to the top of the page and see if it's up there somewhere!!! If you haven't chosen the finish yet, you'll appreciate those who add it to there signature - especially when you see ones you really like and the plastered pictures are at the end of a many, many paged thread. Try finding that info through all those pages!! Lol!! Others on here may need/want some more technical equipment specs, but it looks good to me.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Quote Originally Posted by Geosage View Post
    Ok, so I've done my homework and now know what/where Inland Empire is and also what an alluvial fan is. I feel I can knowledgeably continue to read this thread.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2012
    Tallahassee, FL
    30,620
    LOL me too ^^^^ I love learning new things!
    Kim
    Jul 2016
    231
    Dig crew (a different one) started at the 'crack' of 8:15-8:30 this morning. We were taking bets yesterday if they'd be able to finish digging today. They got off to a later start, but thus far have been moving pretty quick.
    Jul 2016
    231
    Re: New Pool - Inland Empire, CA - Dig day #2!
    Mid-day update, the hole is gettin' deeper, slowly but surely. Boulders are the bane of our existence, but they're gettin' em. We realized that with the 42" rise of the spa above the pool and the pool being 6ft deep at that end, it'll be quite an imposing 10ft wall of gunite once shot over there. Exciting!
    That's a keeper. One of the ~20 or so boulders that size (this is actually a midsized one) we've taken out. We're keeping the nice ones.
    Bring forth the ditch witch! She arrived mid morning, and the diggers were quite happy about it.
    The hole is getting deeper and the sides are becoming much more clear
  20. Back To Top    #20
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    That's nuts! What town are you actually in? Corona, Lake Elsinore, Temecula/Murietta etc?
    We lived in Temecula after living in Scripps Ranch down South.
    Luckily our property in Temecula wasn't as bad as you're showing for the boulders etc.
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
