Thread: High alkalinity issue
    Jul 2016
    Corning, NY
    1
    Hi I am new to the forum and owning a pool. I have been having a high alkalinity problem, but my PH is a steady 7.5, CYA is 0, hardness 340, and FC was 0 . I have added a gallon of MA to get the TA from 220 down to 170. Waited a week and now added another gallon. What should be my target TA.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: High alkalinity issue
    Welcome to TFP!
    If your PH is steady then there is no reason to lower your TA. Just enjoy that stable PH!
    Aug 2014
    Northern IL
    4,615
    How are you testing and how does your water look?
    30,419
    Pooldv has given you good advice.
    I know you didn't ask but 0 FC and 0 CYA is flirting with disaster in your pool. Far more important than the TA is to get some chlorine in your pool and CYA to protect the chlorine.
