Thread: New Heater recommendations please.
    May 2016
    Edison, NJ
    5
    We are growing weary in our attempts to repair our 15 year old Teledyne Laars Lite Model LLG325N-C heater. the persistent problem is that although it will light, it keeps cycling off before the water temperature reaches the pre-set level. Sometimes it will run for a week and then stop. Sometimes it cycles rapidly. Many different technicians have serviced it and many parts have been replaced. Pressure switch, high limit switches,pilot assembly, temperature control assembly, and most recently, the gas valve. If this doesn't work (and I don't hold much hope for it) what brand and model do you recommend for my pool? I have a 17X35 oval pool, it is 8 feet deep in the deep end. Approximately 25,000 gallons of water. I have a regular chlorine system with an automatic chlorinator. I just replaced the liner. I have a natural gas line hooked up to the existing heater. I use a Pentair sand filter with a 1.5 HP Hayward pump.
    Any assistance would be greatly appreciated.
    Amy
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: New Heater recommendations please.
    Raypak gas heaters are by far the favorite gas heater on TFP.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Raypak! The Raypak is similar to your current unit in that it doesn't have extra parts that can fail and need replacement down the road. Plus they also have a very good track record and longevity.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
