Thread: Fiberstars 6008 trips gfci
    May 2016
    Las Vegas, NV
    7
    My Fiberstars 6008 trips my gfci. Fuse to the color wheel blows and I don't see an obvious short. Ant ideas?
    Pool built in 1999 23,000 gallons, 2 hp Pentair Whisperflow, Clean and Clear 520, Caretaker 99, Fiberstars 6008 Ultra Pure ozonator
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Fiberstars 6008 trips gfci
    It is being shorted somewhere, the GFCI is not seeing return voltage a tripping.... can you test the line/cord with a multimeter?
    Mar 2017
    Antelope/ca
    4
    Any update on this by any chance... I'm going through the same exact thing
    Apr 2013
    Sacramento, CA
    2,769
    Fiberstars trips GFCI or internal fuse on color wheel blows or both?
