Results 1 to 9 of 9
Thread: help with cleaning leaves of the bottom of the pool
    Jun 2016
    Southeast Missouri
    24
    Several storms with high winds have come through in the past week and lots of leaves are getting into the pool and sinking to the bottom. How do you get these out of the pool? I have tried to use the vacuum to get them out, but mostly all that does is stir them up of the bottom of the pool. I try to use the net to scoop them up, but again mostly all this does is stir them up of the bottom and I cannot scoop them out. In the shallow end I can scoop them up pretty well, but in the deep end I cannot get them. What do you all do when this happens to get the leaves out?
    18 x 36 ft inground rectangular pool with vinyl liner, shallow end 3 feet , deep end 8 feet (33000 gallons?)
    Tagelus sand filter, Pentair Superflo VS
    Aug 2014
    Northern IL
    4,615
    Re: help with cleaning leaves of the bottom of the pool
    I use the leaf rake touching along the bottom pulling towards me and occasionally backing up a few inches if the leaves start coming up from the bottom. Hope that makes sense.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I push the leaf rake away from me.
    Aug 2014
    Northern IL
    4,615
    Whatever works! I am short so maybe the pull works better in my situation. I have tried it both ways and pulling is more effective for me; less giggling. I also make sure to get a leaf net with a good scooper edge to drag along the bottom. Try both, slwethrs, and see which works best for you!
    DFW, TX
    24,485
    Right, like this one, Swimline Professional Leaf Rake 8040
    Aug 2014
    Northern IL
    4,615
    Yup! That's the scooper edge I mentioned. Nice link.
    30,419
    The primary answer to your question is to get a VERY heavy duty leaf net (and Pole).
    Jun 2016
    Southeast Missouri
    24
    thanks for you replies. I was finally able to use the vacuum and carefully suck most all the leaves up with the vacuum this time. it just took a little more patients to get them without stirring them up into the water. I will plan on getting a net like the one in the link as soon as I can.
    Jun 2016
    Southeast Missouri
    24
    thanks for the responses. I went to pool supply last week and they had a couple of different ones, but the nets did not have the flat edge like the on in the link. so I just got the flat net that works really well for leaves on surface. guess I will plan on getting one like shown in the link with that flat edge. I tried again with the vacuum and with a little more patients I was able to get them sucked up through the vacuum hose, just by slowly placing the vacuum head on top of the leaves and leaving it there long enough to suck the leaves up.
