Thread: Pump stopped working....
    Ncdamsel's Avatar
    Jul 2015
    Garner ,NC
    65
    We have a mineral springs control panel with timer and a hayward 1.5 pump. The pumps power is hardwired thru the panel.After a storm the pump stopped working. We called our pool guys and they installed a new pump the next day. The problem is we had to plug the pump directly into an outlet versus the old way thru the panel. The pool guys said that are not sure why this is happening. Any ideas ? fuse?
    13,995 gallons 24 X 52 / above ground pool.../.SWG/ sand filter/ vinyl liner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pump stopped working....
    sounds like the minerals springs panel got fried, any way they can test it
