Thread: Cracked Elbow
    Aug 2014
    Olathe, KS
    25
    Cracked Elbow
    Hi
    I broke off one of the elbows on the chlorine feeder. I went up to the local hardware and found a couple elbows in the sprinkler section, brought it back and installed them. I replaced both elbows while I was at it. Fast forward a couple of weeks and now one is cracked and the other is leaking, probably cracked too. I'm assuming that it's the material they were made of. Any suggestions?IMG_0026.JPG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: Cracked Elbow
    You can probably order the parts from INYO Pools or Sunplay.
    Aug 2014
    Olathe, KS
    25
    Re: Cracked Elbow
    I ended up finding a 1/2 " threaded pvc elbow and just running a pipeIMG_0034.JPG
    22,548
    Re: Cracked Elbow
    The irrigation fittings you found were probably Polyethylene or Polybutylene and neither are very resistant to high chlorine or low pH, and that tablet feeder sees both.
