Thread: help
    Jul 2016
    Laurel, Delaware
    1
    Question help
    We just bought an above ground 14x42 vinyl lined pool. Problems from the start unfortunately.. but we ave been able to work it all out so far. I just tested the water with strips because there is a light green tint to the water. The strips read low on total hardness, total chlorine, free chlorine, ph, total alkalinity, and stabilizer. How do I fix this? any help will be greatly appreciated!
    I have a 14x 42 above ground pro steele pool.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,247
    Re: help
    Welcome to TFP! Good to have you here
    You're right at the borderline, in terms of pool size, between using a test kit and killing off the algae, or draining and refilling.
    I'd recommend the methods outlined here: Pool School - Guide for Seasonal/Temporary Pools
    This involves draining, refilling and accurate chemical additions. You will need a slightly better source of testing with a test kit that costs around $25. Your pool will be sparkly clean and will need less maintenance through the rest of the season.
    As you're deciding, put 2 cups of 8.25% bleach in it mid-morning and again in the evening to keep the algae from getting out of hand. Use plain cheap unscented (not splashless) bleach that has the concentration listed on the jug.
    If you decide to go this route, we'll be happy to answer questions as you work through it.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2014
    15,109
    Re: help
    ^^ Good advice already. Also make sure to visit the TFP Pool School page and visit/bookmark many of the links you see in our signatures. They'll help you later. Nice to have you with us at TFP.
