Thread: Algicide or not
    Jul 2014
    kamloops bc
    39
    Algicide or not
    Just opening my pool pump has been running for two days slamming it with chlorine, clearing up nicely am about to brush the pool walls have been in the habit of pouring algicide around perimeter before brushing but I am now wondering if that is a waste ?? Should algicide be added to pool if no algae ????
    14 x 28 IG, Hayward sand filter, Hayward 3/4hp pump, auto puck chlorinater,(used only when away) Hayward Natural gas heater, vinyl liner
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Algicide or not
    If you follow our SLAM method taught in Pool School, you almost never need to use algaecides. Some algaecides are just weak linear quat type algaecides which chlorine readily destroys and causes foamy water. Other algaecides can contain EDTA or worse, bromine, which causes a huge chlorine demand (in the case of bromine based algaecides, the chlorine demand is permanent). Finally, other algaecides are based on copper sulfate which, as the chemical suggests, adds copper to your pool water which creates staining and green hair.
    Please read the SLAM article in Pool School or the article we have on opening pools. It will show you how to get your pool from green to clear without dumping tons of money on useless chemicals.
    Matt
    30,403
    Re: Algicide or not
    Absolutely not. Algaecide is certainly mislabeld because it is more of a preventative that a killer.
    Just keep your FC up to the correct values and you will never need algaecide.
    Jul 2014
    kamloops bc
    39
    Re: Algicide or not
    I have spent a lot of time in the pool school which probably led me to ask before pouring just sometimes hard to get over bad habits �� Thanks for the quick replies !
