Thread: Treat pool or wait till testing kit arrives
    Jul 2016
    Park River, ND
    14
    I live in a rural area so I have to wait until Monday for my Taylor testing kit to arrive. We have had our pool up for two weeks. I began by adding Arm and Hammer tablets and Chlorine tablets which got my pool levels out of whack, and decided to forgo that method and follow advice on this site. The cheap test strips I'm using claim my PH is 9, ALK is within normal range, and no FC. I was hoping to wait until I get a more accurate testing kit to treat the pool but the water is getting cloudy and will not keep chlorine. Should I just wait until Monday when I receive my Taylor kit to treat? Thanks
    10K, AG, 3000 GPH Krystal Clear Sand Pump, Taylor K-2006
    Jul 2015
    Central Valley CA
    1,109
    Re: Treat pool or wait till testing kit arrives
    I would add 1/2 gallon of bleach each day till you get the kit regular bleach not scented or splash less
    And welcome to the forum
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Which test kit did you purchase?
    Sounds like you'll need some bleach and muriatic acid when the kit arrives, so I'd purchase a gallon of MA and 8 or so gallons of bleach. Plain, unscented bleach wherever it's cheapest and the highest concentration (8.25% or better). That will get you started.
    Even before the kit arrives, you could add up to a gallon of bleach per day to keep it from getting worse.
    Check out the ABCs of Pool Water Chemistry and Pool School - Recommended Pool Chemicals as well.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Jul 2016
    Park River, ND
    14
    I got the Taylor 2006 kit coming. I purchased the muriatic acid and bleach already but will just add the bleach then while waiting. Thank you.
