Results 1 to 7 of 7
Thread: new light grey marble dust - giant streaks. What do I do? please help
    Jul 2016
    Merrick/NY
    5
    Hi everyone,
    I just had contractor come in and do light grey marble dusting of my pool. After they were finished and I came back from work, I looked in the pool and saw a very uneven color of cement in the pool while I was expecting to see one smooth light grey finish. Naturally, I'm freaking out now because as we all know, this is not cheap at all. The pool company tells me it takes 20 days to cure and that this will even out. Is this really the case? Will it even out on it's own once the water is balanced or am I stuck with these giant streaks? what should I do? please help
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    Re: new light grey marble dust - giant streaks. What do I do? please help
    I am not sure what they did. How do they do a light dusting? Is this new plaster? Has it been acid washed? Sorry for my questions but I want to make sure we know what is what.
    Kim
    Jul 2016
    Merrick/NY
    5
    Basically, this is a new plaster in a light grey color. The old plaster needed to be resurfaced so they put a bond coat on an existing plaster and then applied a new plaster in grey color. They did not acid wash
    Jul 2012
    Tallahassee, FL
    30,620
    Will they do an acid start? As in put LOTS of acid in the water after it is filled?
    Another way to start the plaster is for them spray the acid on the plaster then rinse it off. They then start filling it with water.
    Here is a link on new plaster BUT run it by your PB before you do anything:
    Pool School - Start-up New Plaster
    You also need a good test kit to help keep this new plaster looking it's best and help it last a good, long time. Look in my siggy for the one I think is the best bang for the buck.
    Kim
    Jul 2016
    Merrick/NY
    5
    Thanks for the info, Kim. I already bought TF-100 test kit so I'm all set there.
    I'm just curious if anyone had their pool replastered in grey color and if they experienced the same thing and whether or not the streaks disappeared.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    It is very common for colored plaster (plain plaster with colorant) to have streaks or mottling. He should have warned you of that beforehand. Absolutely push him on this. Ours has it and was expected.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jul 2016
    Merrick/NY
    5
    Quote Originally Posted by bmoreswim View Post
    thanks for the reply. so yours stayed exactly as it was on day 1? none of the streaks disappeared?
