Thread: Attempting to setup Pump on new AGP this evening- please HELP!
    violet-mermaid's Avatar
    Mar 2015
    Baton Rouge, LA
    73
    Question Attempting to setup Pump on new AGP this evening- please HELP!
    Hi guys. So the pool installers started installing our buried AGP 3 weeks ago, and it's still not complete. Was **supposed** to be done in 2-3 days, but they cancelled more days than they showed up. The hard part is done- hold dug, yard leveled, pool assembled, liner installed. The pool was setup on Monday, and we were told to fill it up halfway with water and they would be back the next day to setup the skimmer and pump/swg. Well, it's Friday and they still have not been back. The water is getting yucky on the top, and it's time to get some filtration going. My husband and I are going to attempt to setup the equipment this afternoon. Here's what we are working with:
    And our equipment:
    Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    Amazon.com : Intex 120V Krystal Clear Saltwater System CG-28667 with E.C.O. (Electrocatalytic Oxidation) for Above Ground Pools : Patio, Lawn Garden
    What do we need to hook all of this up to the pvc? The guys left no fittings or anything. Will the hoses that came with the pump hook up to this? Any help or advice would be great... I'm SO ready to be done with this!
    Also, here's a link to the pool install if you're curious...
    Buried AGP Pool Build
    12 x 24 Buried AGP 6,800 Gallons | Intex 16" Sand Filter | Intex Krystal Clear SWG
    Hayward Thru-Wall Skimmer | TF-100 Test Kit |Hayward 900 Wanda the Whale
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Re: Attempting to setup Pump on new AGP this evening- please HELP!
    Quote Originally Posted by violet-mermaid View Post
    And our equipment:
    Do you have all of the parts that came with the pump, filter and SWG? I am not an expert but the SWG might be undersized for your pool. They recommend to do 50% the size of the pool. You would have to have an expert chime in on this. You can still do all the piping and just cut that in later. Just wanted to toss that out there before you install seeing the next step was only $50 more on Amazon.
    I used bleach in my pool for the first few weeks till I got the electric done.
    15'x24'x52" Saltwater 5000 Oval AGP, Hayward S180 Sand Filter / 1.5 HP Power Flo Pump, Hayward AquaTrol Chlorinator, TF-100 + Taylor K-1766
    Mar 2015
    Baton Rouge, LA
    73
    I actually have the SWG that says up to 15,000 gallons- I bought it from Walmart. But yes, we do have all of the parts that came with everything.
    How much liquid chlorine should I add now, if any?
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Check pool math but with mine I just dumped a gallon of bleach in while I was setting up and just checked every few days. If you put unions on the end of those pipes you can always redo the pipes later even if you don't have all the valves. They also make connectors to go from flex to PVC. That way you can get everything running until they come back to finish. If you do pipe it, it took me about 3 hours to do mine. Use Teflon tape on the threaded connectors and only hand tighten.
    Mar 2015
    Baton Rouge, LA
    73
    I relayed the message to my husband- not sure if we know anything about these unions or flex connectors lol. He's coming home now so we can scratch our heads together LOL. I know that the pvc pipe is 1 1/2in...
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Take a look at my setup. Union is the bigger round pieces. Just make sure to get schedule 40 connectors
