Results 1 to 16 of 16
Thread: HELP, Pool is too warm here in Texas! Can it be cooled without a chiller?
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    Ok, I've read the post from 5 years ago about building some jets to cool the pool. That is exactly what I was planning to do, unfortunately for me, my return lines are 2" (or less but not 1-1/2") MALE. Does anyone have this type of set-up and can it be done? I really don't want to purchase a chiller if I can save myself 2k! Temp is averaging 91 so far in June/July. I'd love to get it down to 85 at least.
    Pool Details - 20,000 Gallon Chlorine, IG, Dark Pebble Finish, Cartridge Filters
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,620
    Re: HELP, Pool is too warm here in Texas! Can it be cooled without a chiller?
    I'm quite sure you can cobble together some pvc adapters and fittings to neck "up" a standard aerator flower to your 2 inch return.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Build yourself a fountain (aerator), that will attach to a return, and run it at night, evaporative cooling. Works well.
    Heres a link or two:
    A Cheap Pool Cooler for the end of Summer
    Pool cooler and pool accessories made from PVC
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    I've tried, but again the only problem i have is finding something to replace the cap/eye (pictures attached) that goes over the return pipe.
    I was trying to make a few of these, but have not found any type of adapter that will connect to the return pipe.
    TexasDeano's Avatar
    Aug 2015
    Frisco, Texas
    137
    I worked with someone who attached something to one of his jets that came up above water level and sprayed the water in a fan shape across the pool. He said if he runs that a night the cooler night air will drop the temp of his pool. Not sure what the gadget is called. Maybe someone else on here knows more.
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    UPDATE....Ok, I have an update. Call me an idiot, but I did not realize there was a female fitting in the return line. I had to buy a "Key" to remove it and then was able to find a
    1-1/2" fitting at Home Depot. Now I can begin the project. I plan to make three spray jets and run them tonight. The pool was at 91 at 10 am this morning and now at 93 4:30pm CST here in The Woodlands. If I can get it below 90 with these I will be as happy as a kid in a candy store. I'm hoping for 85 degrees.
    30,421
    Now you're cookin'! Remember, the best cooler will throw the droplets HIGH into the air for maximum evaporative cooling. You may not create enough psi with three returns to get the height that will be really effective. I cap off two of my returns so my entire (pretty strong) pump is running through 4 - 1/8 " holes. My psi is around 28 (up from 11) but I can throw that water almost 25' high.
    Run it 24/7. You'll get evaporative cooling day and night and your pool will be cool....promise!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Watch your PH though, all that aeration will raise it.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Now you're cookin'! Remember, the best cooler will throw the droplets HIGH into the air for maximum evaporative cooling. You may not create enough psi with three returns to get the height that will be really effective. I cap off two of my returns so my entire (pretty strong) pump is running through 4 - 1/8 " holes. My psi is around 28 (up from 11) but I can throw that water almost 30' high.
    I did "lots" of 1/16 inch holes but yours sounds more successful than mine. Maybe I need to rethink it. I got too afraid to shut 2 of the three valves and end up sending more water through so I just shut off jets in the swim out. Maybe I need not be so timid and go ahead and test that pressure.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,421
    Aimee,
    As long as you have just a little flow, you will be fine. Your psi may come up to 30+ and that's all your pump can do....still no harm. If you capped off the pump completely, your psi would be at 35-maybe 40 and that's as high as your pump can go. That's still OK but the problem with no flow is the water will overheat since it can't get out of the pump and will actually melt the pump body.
    Anyway, what I am saying is with any flow at all, your pump is fine and less flow means the higher pressure you have to catapult those drops high into the air.....that's when the fountain becomes effective. You can actually feel the falling drops as cooler than the pool water.
    I also think it's important to run 24/7. If you have kids they'll play in the "rain".
    DFW, TX
    24,497
    From what I hear Skippy builds the best fountains ever ... Skippy's New Fountain
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Duraleigh,
    Yes....I can feel the drops are cooler with mine but pool temp didn't seem to get a notable adjustment. I will try higher pressure this weekend. There is another benefit we've found for the sprinkler in general which applies to anyone reading with horse flies. We have an issue with horse flies and we've found that taking cover under the "rain" water from the sprinkler helps.
    Daughter got bit by one the first year with the pool and next day face was so swollen her eye was shut. Bite was on the head through the hair. We saw it on her.
    So the sprinkler cooler might provide cover from horseflies too
    Apr 2010
    East Texas
    9,620
    I can run mine overnight and drop 5 or 6 degrees.
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    UPDATE____ Ok, here is my (not perfect) finished job. I plan to make two more and see how it does. I tested the temp this morning after letting these two run last night and it was 88 instead of the normal 89, so that's something.IMG_8781.jpg
    Dejavu21's Avatar
    Jun 2016
    Spring, Texas
    25
    Ok, I thought I would give everyone an update on if my pool fountains worked.
    I started closed 3 of the 6 returns and left 1 open while running the two fountains. I ran my pump on high (had a PSI of 22) and the water actually was shooting out about 4 feet (further than the pics below on low). I started this at 5pm on Thursday and the temp was 97F here in Spring and humidity was 50%. I ran them until Saturday morning. Below are the results.
    DAY/TIME Outside Temperature Humidity Usual Pool Temp Current Pool Temp Temp Change with Fountain Time Elapsed
    Thursday 5PM 97F 50% 93F 93F 0 0
    Friday 6AM 80F 87% 89F 86F -3 13 hrs
    Friday 5PM 97F 42% 93F 90F -3 24 hrs
    Saturday 6AM 80F 88% 89F 84F -5 37hrs
    Saturday 11am 85F 73% 91F 85F
    So, after running for 36 hours over two nights, i got the pool water down to 84F. So, i think i will run these every Thursday-Saturday morning and may again Saturday night in able to enjoy a cooler water temp during the day!
    Quote Originally Posted by Dejavu21 View Post
    Mar 2015
    Sugar Land , TX
    424
    So if running on high ( 3600 rpm ish ) for 36 hours it must be costing $9 to cool down based on 0.12 cents per kw ( estimate). I bring this up just to compare what a chiller might cost to run. Your way is probably cheaper in the long run.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
