- Jul 15, 2012
- 604
- Plaster
- Hayward Aqua Rite (T-15)
So my spa Aquapure 1400 started generating 172 185 and 186 error codes. I assumed issue was the tri-sensor and I had an extra one so I decide to install it. Salt had been at 3100 before the error popped up. When I put new board in, I am getting three issues: (1) salt reading 4200, which is causing high salt error 145; (2) temperature reading 37-42 F, which is purely incorrect as it is 80 degrees outside and water was 104 yesterday; (3) no flow is indicated.
My Tri Sensor is the kind with the try-sensor adaptor - not the latest with the extra interface module. I tried to push the button on the adaptor but it has not helped. Flow light on adaptor is blinking. Button does not seem to do a thing.
