Thread: Wanting to add a sprinkler to one of my returns
    Jun 2015
    Davenport, Florida
    14
    Hello all
    Wanting to add a sprinkler to one of my returns as there are 4 in my pool, wondering if anyone can tell me the size of the threads to be able to pick up the pieces? they seem to be standard eyeball returns
    many thanks
    Bill
    12,500 In Ground Gunite Free Form, 1 Skimmer 4 Returns
    Screened enclosure, TF-100 Test Kit, Speedstir
    Sta-Rite 1hp Pump
    Pentair 100SF Reusable Filter
    Haywood Cl100 Auto Chlorine Feeder (currently disabled)
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Wanting to add a sprinkler to one of my returns
    Do you have one return that is meant for a cleaner? That's the one we used when Skippy made our Pool Fountain (link in siggy line). It didn't require us to remove any fitting.
    Can you post a picture of your return(s) that might be used for it?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    A 1.5" threaded adapter is the standard size for eyeball returns. You should be able to start with a 1.5" threaded adapter.
    http://www.pvcfittingsonline.com/436...e-adapter.html
    Isolated Spa - 345 Gallons
