Thread: TA conundrum...
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    TA conundrum...
    So heres my battle...
    current TA is 160ish...
    Fill water TA is 180
    Ive been playing he MA game trying to get my TA down. Wait for PH to get up to about 7.5, hit it 32oz MA to take it down to 7.1 while dropping TA about 10 every time I do it. Ive managed to drop it about 20 ppm in the last few weeks but by the time I get my ph back up enuf to drop it again, the water level drops and I have to add more fill water, almost negating my work with the MA additions. I had a small tear in the liner that was probably contributing to the water level but that is fixed so hopefully the water loss will be minimal now. Im also trying to raise the temp of the pool (only 6hours direct sunlight a day) so the cover stays on most of the time no allowing the PH to rise faster.
    I don't want to add too much MA to drop it below 7 but it seems like its 1 step forward, 2 steps back.. IS there any other way to drop TA faster without dropping PH to low? IS a higher TA really that big of an issue?
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    30,429
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    Re: TA conundrum...
    Why are you lowering it? How does pH act if you leave it alone?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: TA conundrum...
    I read calcium scaling in a vinyl pool is no good... I have average CH readings and don't really want any contributing factors. PH is mostly stable with the cover on.. Take about 2 days to come up to 7.5 after I add MA. Even with the cover off and aeration the PH doesn't come up too fast.. Ive never seen it above 7.6
    13500 gal
