Thread: Pentair 320 Inline Chlorinator - Top Feed vs. Bottom Feed?
    tempo013's Avatar
    Jul 2016
    Spring, TX
    5
    Hello,
    I have a salt water pool and my AquaPure 1400 chlorine generator is currently not working (may have to create another post for that guy). Anyways, I tossed some 3" tabs in my Pentair 320 and I am now generating chlorine.
    My question is...What is the difference between the Pentair 320 being setup as Top Fed vs. Bottom Fed? Mine is set up as Top Fed but all the user manuals I found online only discuss bottom fed systems.
    Tony Tempo
    ~15,000 In Ground Salt Water | Jandy CL460 Filter | Pump - Need to Update | Heater - Need to Update
    Jandy AquaPure 1400 Chlorine Generator | Pentair 320 Inline Chlorine Generator
    Polaris 260 Vac Sweep Cleaning System | Booster Pump - Need to Update
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Pentair 320 Inline Chlorinator - Top Feed vs. Bottom Feed?
    Welcome to TFP Tony
    Unless you need to up your CYA a bit I'd quit using the tablets and switch to liquid bleach for a chlorinator until you get the SWCG fixed.
    The tablets add chlorine and CYA. The chlorine gets used up but the CYA doesn't. It just continues to build up. The chlorinator is kind of nice if you end up being gone for a few days and your CYA level can handle a little added CYA. Using them all the time is where people can run into trouble with excessive CYA levels.
    Solar Blanket, Well Water, Borax Added. 68
    30,403
    To answer your question, I think you can set it up either way. We are really opposed to pucks though so you won't find many on here to have an opinion other than not to use one.
    tempo013's Avatar
    Jul 2016
    Spring, TX
    5
    Thanks for the feedback. I am currently working on getting my SWG up and running properly. Please see the post in the link below and comment if you have any input. Thanks a ton!
    AquaPure 1400 SWG Tri-Sensor Installation
    Tony Tempo - Spring, TX
    ~15,000 In Ground Salt Water Pool w/ Spa and Waterfall
    Filter - Jandy CL460 | Pump - Jandy PHP 2.0HP | Heater - Need to Update
    Jandy AquaPure 1400 SWG | Pentair 320 Inline Chlorine Generator
    Polaris 260 Vac Sweep Cleaning System | Booster Pump - Hayward Model 6060
    Jun 2015
    Missouri City, TX
    87
    From what I've read, bottom feed is the standard install and you move it to top feed if you aren't getting enough flow to dissolve the tablets.
    With my pool (and many others it seems) even with the unit in top feed it still doesn't provide enough flow to produce enough chlorine to keep pace with demand in summer. Installing the high flow kit (R171099) taking the inlet feed from further upstream where the pressure is higher, seems to have improved the situation for many people. Personally I've used it for a year and am junking it and move to liquid chlorine....
    Graeme // 15k gal 29x15 geometric IG w/750 gal spa, Wet Edge Northshore Tahoe, travertine coping and decking, Clean & Clear Plus 420 sq ft cartridge filter, Intelliflo VS pump, 1hp water feature pump, Easytouch 8 w/wireless handheld, Racer pool cleaner, 400,000 BTU Max-E-Therm heater, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5G LED lighting, bubblers, pencil jets, TF-100 w/SpeedStir, Borates & Salt. Finished and filled June 2015!
