Thread: Reconstruction of Intex 12x30
    Apr 2016
    Florida
    29
    Hello! Technically I am not new, but I am trying to set up a new liner from my 12x30 steel frame intex. I had some issues with being unlevel, take down, relevel and fill again. Then a pump leak fixed. Lastly a liner leak which led me to send it back for a replacement. I never did locate the leak, so I am not sure of the cause. But I do wonder if it could have been from the pavers I used to support the legs. They didn't dig in really. In fact, hardly touched at all, BUT now I'm concerned about using them again. Half of summer is gone and we're still trying to have a pool to enjoy. The base is sand. Is it necessary to have paver base for the steel legs. I will if it will be a disaster without, but I will try to position them perfectly before filling. Opinions, tips and tricks? Thanks!
    AG Intex 12 ft x 30 in, approx 1800 gallons (90% full)
    Installed and filled 19 May 16
    5 way test kit
    Running under seasonal/temp setup
    Consideration of young child's skin disease
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Reconstruction of Intex 12x30
    If you make sure the pavers are level with the ground, they won't rub on the liner. They do ensure that splash out over the top and rain don't cause the legs to sink. (I didn't have them under my 18' metal frame and the legs did indeed sink a bit. I then had to find a way to place them under after the pool was up.)
