Thread: Getting some things straight
    Jul 2016
    Boca Raton, FL
    8
    Just wanted to clear a few things up after reading a bunch around the site. When I moved in, the pool (16x32 in grd 19200) service told me that the yellow stains (that don't come off when brushed) on the plaster lining was just because the lining was old and needed to be replaced. Reading here, it seems that isn't the case, and that the stain can be determined to be either metal based (using a vit c tab) or organic (using a trichlor tab), right? Also, cloudiness is caused by algae, and cloudiness when brushing is also algae, right? Waiting for my test kit to do a OCLT, but the more I read, the more it is looking like I might need to SLAM. Gonna wait and get my levels right according to the TFPC method after I get my test kit before I do anything. Just wanted to make sure I was understanding a couple of things. Thanks
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Getting some things straight
    There's always exceptions, but as far as a generalization, you are correct about types of stains and cloudiness. There are other things that can cause cloudiness, but you are on the right path to determine first if algae.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2014
    15,004
    Basically you are indeed understanding things correctly. There are exceptions at times, but your test kit results will help us with that. Later, a pic or two may help as well. Good to see you're doing your homework though. That will help you when your kit arrives. Let us know if you have any more questions.
