Thread: Seen only at night...
    Oct 2015
    Windsor, ON
    12
    At night when the lights are on, it appears as though the pool pump is blowing in cloudy water. I took a few photos of the return as well as in front of the pool lights.
    It might be hard to see, but it almost looks cloudy yet the water is clear. Is that normal?
    The water is a warm 85 degrees.
    FC 5
    CC .5
    PH 7.6
    TA 100
    Calcium 290
    CYA 80
    16' x 34' Freeform Vinyl IG Pool, ~ 15,000 Gallons, Pentair Intelliflo VF 3HP, Pentair System:3 Cartrige Filter, Pentair Max E Therm 333 Gas Heater, Pentair IC40 SWG, Easytouch 8, Deck Jets, Intelibrite 5G Pool & Landscape, Built April 2016
    Feb 2015
    Chandler AZ
    938
    Re: Seen only at night...
    I see you have a SWG. It might be microscopic bubbles from the SWG - which is common. You could try holding a white sock over the return for few minutes and then checking to see if the sock caught anything.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Yep, my guess is air bubbles too. Or turn off the SWG to confirm.
