Thread: Removing sand from floor
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Hi all. Just replaced broke laterals and now in the process of removing a bit of sand from the floor. Trying to vacuum to waste and then tried to filter but not getting very far. Is there a better way to do this?
    Thanks!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    FloridaPoolGal's Avatar
    Jan 2016
    Altamonte Springs, FL
    98
    Re: Removing sand from floor
    Would a hairnet on your pool net catch the sand?
    Approx. 20k gal, kidney-shaped, inground, concrete pool built in 1974. 33' long. 18', 14', & 15' across. 3' to 8' deep. Hayward cartridge filter (c1200e). 1 hp, single speed motor replaced 12/2015. In-line Pentair 320 Chlorine/Bromine feeder (do not use). Screened.
    Aug 2014
    Northern IL
    4,615
    Check to make sure it's sand by getting a sample. If it is gritty sand, maybe go slower with the vacuum? No need to vacuum to waste for just sand.
