Results 1 to 16 of 16
Thread: 24hrs into SLAM, added too much Chlorine
    Jul 2016
    Tarzana, CA
    10
    Just a matter of time before I needed to come and seek help
    24hrs into SLAM and adding more chlorine to the required 24ppm FC. A second of not paying attention to my calculation I added too much chlorine and ended with 30ppm. Heavy Chlorine smell, bubbles on the surface just like carbonated water, at least some organic matter is being taken care of.
    Should I let it slide back to 24 or do i need to keep it now at the 30 level from now on? I understand that one should not swim until FC is back at 24ppm.
    Balance prior SLAM
    FC 0
    PH 7.4
    CH 250
    TA 120
    CYA 60
    FC for SLAM 24
    Thank you
    Hussain
    20k gal, IG plaster, attached Spa, Pentair IntelliFlo VS 2, Hayward DE Filter, City Water, Taylor K-2006,
    plenty of unidentifiable equipment, capped lines and many more questions
    Jun 2014
    14,957
    Re: 24hrs into SLAM, added too much Chlorine
    You're okay. It will sink down to 24 tomorrow. Just make sure the bleach you are using is plain/regular and NOT splashless or scented.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You can let it slide back to 24 on it's own. It will do so as it takes care of organics. Only need to keep dosing back up to 24 ppm once it drops below. Excessive FC will not speed the SLAM process and will just lead to more FC "wasted" to UV during the day as you proceed.
    Isolated Spa - 345 Gallons
    Jul 2016
    Tarzana, CA
    10
    Thank you Pat
    I was worried at 30 the biofilm on algae is just getting thicker and 24 would loose its effectiveness. Using basic plain 10% liquid chlorine.
    Jul 2016
    Tarzana, CA
    10
    Thank you Joel
    Fully aware of wasting the chlorine. Just wasn't sure if letting it slide back to 24 or have to keep at 30. I wasn't trying to speed things up. Busy fending off my two year old who thinks my toys are way cooler than his and the cute little bottles of the kit help clean the pool. Combined with mathematical mistake of calculating a gal as 64 oz (growing up in metric isn't helpful either). The end result, instead of raising from 18 to 24 I double that.
    Aug 2014
    Northern IL
    4,615
    Hahaha. I don't think algae can mutate that fast to adjust to higher FC. THAT would be worrisome!
    As long as you are following appropriate FC levels, (be they shock or target-ish), you are fine!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    And keep scalping that dreaded algae with the brush. Get mad at it!
    One of my grandies, 4 yrs old, likes to help me count the drops. And if the CC turns pink she runs over to the pool squealing... someone wee'd... someone wee'd.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2016
    Tarzana, CA
    10
    Marina
    Thanks. Better ask than be sorry and have the algae laught at me: "we survived 30, bring on your measly 24". I can just hear the chatter
    Jul 2016
    Tarzana, CA
    10
    @ needsajet
    Precious the little ones. One big box home improvement store I once bought a test kit which had the numbers 1 to 5 on the bottles. My son counts the bottles or picked a bottle and told me what number is written on it. It was all fun until he realized the tops can be screwed off, just like toothpaste, mommies make-up and perfume or his snack pouches.
    What follows is the perfect example of t he logic of a two year old: And how do we clean up the pool best? Lets drop the stuff straight into the pool. Why the hassle of scooping out 25ml at a time and doing it bit by bit? It's a 20000gal pool at that rate Papa will never get the pool cleaned. Let's help the old man.
    Lucky I caught on before he was able to "help" me.
    I am srubbing like a mad man. Just bent one of the poles. It now will stay extended till the end of its days.
    needsajet's Avatar
    Jan 2016
    4,224
    Hahaha, that's funny, not the pole but the toddler You got this And yep, always good to ask, no pool question too big or small for TFP!
    Did you know that you can become a TFP supporter for a very modest tax-deductible one-time donation that includes perks? Big button at the top explains it all. Helps us keep the bits and bites flowing. No pressure
    Jul 2016
    Tarzana, CA
    10
    I am planning on supporting this site. Very shortly.
    An overnight shift of scrubbing the pool until 2am resulted in FC 19.5, CC 0.25 at 7 am (plus a wife who thinks I have always been crazy, who is now convinced that I definitely went over the cliff). Must have scrubbed a lot of matter off the walls. So not wasted chlorine. Seems I have way to go, yet i am getting somewhere. Need to get more chlorine on the way home and have to listen to the "experts" at the store once again that I am doing it all wrong.
    Feb 2014
    Central Minnesota
    5,080
    Skip the pool store, unless that's the only place you can get liquid chlorine. What are you buying there and what's the price? You may be able to find just as good of a deal in regular household bleach at WalMart or other high volume sellers of bleach.
    Keep after it!
    Jul 2016
    Tarzana, CA
    10
    Local OSH has KemTek Liquid Chlorine for sale 2gal/case $4.99 (regular $7.49), yet it comes with the expert standing around the isle. If my math is right this is the best cost I find around here. Unless, of course, I once again did mess up the gallons and this time a gallon was 256oz
    Feb 2014
    Central Minnesota
    5,080
    2.50 a gallon is a good price. Have earplugs you can wear in the store?
    Sent from mobile device. Beware of brevity and spelling errors!
    needsajet's Avatar
    Jan 2016
    4,224
    Ask them to show you some pool toys and give you a rundown on how they're used in the pool. That can't hurt a thing.
    Jul 2016
    Tarzana, CA
    10
    Clearest pool in a year. Balanced as well. All I am doing now is testing the water and adding chlorine. Thank you TFP and members for your help.
    As promised I just made a donation. Basically the amount I saved not using the nonsense I was talked into over the last 12 months.
    No I need to figure out where to offload all those chemicals which are just sitting around now.
