Thread: Liner Issues
    Jul 2016
    Blue Springs
    1
    Liner Issues
    Moderator comment: This post was separated out from this thread: Liner loose spots and wrinkles on bottom
    I'm having the same problem. I jabber a 24x15 Esther Williams oval aluminium pool. We put more sand in bottom. Put liner in. Liner didn't fit.took it off.dug out sand. Put liner in ,still didn't fit. Raised one side of pool up that was sinking bc is 40 years old. Raised it 2 inches, tried liner again still had wrinkles. I'm tempted to pull out back and take more sand out of the bottom?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liner Issues
    Welcome to TFP
    It is not very easy to get the bottom "just right" most get it close enough.. I have 3 small wrinkles in mine and have had no issues with it
