Thread: In Need of a good brush
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    i am looking for a good quality brush for my vinyl pool. i see there are alot of different ones to choose from but i just dont know which one to buy. i dont want to hurt my liner from brushing with a very stiff brush. i dont have to worry about brushing off any algae (as of now). any suggestions would be greatly appreciated.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: In Need of a good brush
    Most any brush with plastic bristles will do. I like the brushes with the upward curved ends to help get better coverage in corners and rounded areas. The Wall Whale brush is nice as it helps you put pressure against the walls or bottom as you push.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I like this one, Paradise 18 Turbo Brush Swimming Pool Brush | PTB100
    It gives nice extra pressure without having the full giant whale tail.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by pooldv View Post
    I like the looks of that... if only it came in a longer version!
