Thread: Bonding pool - Run it back to the panel or just between them?
    Jul 2016
    Jamestown, New York
    2
    When bonding the pool, does the bonding wire need to go between the pool pump and heater only, or does it run back to the panel?
    Thanks
    Nakoma 54" deep 21' Above Ground Pool. It's all resin. We currently have the Frog system but want to switch to salt system at some point. We have an electric heat pump and a sand filter. Just installed 2 days ago on July 5th, 2016. We are very new to all this!! We welcome any help/advice.
    May 2016
    Swansea MA
    62
    Re: Bonding pool - Run it back to the panel or just between them?
    It should run all the way around the pool try and keep it like a foot off the wall. If there is any metal like the bottom rail you should try and hit that in four spots equally around the pool. It should also hit the heater pool water and pump motor. The water is done by a skimmer kit or a bonding nipple that goes inline with your intake hose. It doesn't go back to the panel.
    24 ft round AG 12,700 gal. vinyl
    Doughboy Sequel II Rotary DE filter
    TF-100 test kit. 1st full season
