Thread: Thunder storm and no power
    Jul 2016
    Lizella, GA
    5
    Hello All,
    We just had a severe thunderstorm come through and now there is no display/power to my Aqua Trol system. The timer works but that is all. I have used the diagnostics from https://images.inyopools.com/cloud/d...ting-guide.pdf Everything checks out down to page 11 step H. There is a test for 3 to 5 VDC to pin 1 & 3 to the display board. I have no voltage. Is there other test for the main board that I could try or just change the board? There are no spots on the board that look bad/burned and the voltage limiting resistor looks good.
    Thanks
    Russell
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Thunder storm and no power
    Welcome to TFP
    I think you have trouble shot it very well.. Can you call customer support and ask if any more steps before you change the board
    Jul 2016
    Lizella, GA
    5
    Ordered a new main pcb. Came in today and I am up and running again. I will save the old pcb and see if I can diagnose the problem. Hopefully wind up with a spare.
    Russell Jones
    2014, 30'X54" above ground, Hayward Aqua Trol Salt Water System
