Thread: Frustrating Vacuum
    Jul 2016
    Lakeside
    4
    Frustrating Vacuum
    I have a Hayward Navigator Pro but am having a heck of time getting it work reliably. If I move the valve to provide more suction on the vacuum line then the pump suffers. If I turn up the Intelliflo pump speed up to compensate then its not running efficiently. Just when I think I have it figured out I'll check out back and just see that vaccumm sitting there ! Any suggestions/ideas on how to find the best balance between pump speed, valve adjustment and vacuum run time. Pool is around 25K gallons ...
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,261
    Re: Frustrating Vacuum
    Welcome to TFP! Good to have you here
    You'll need to set the valve and increase the pump speed to whatever level is needed for the vacuum to perform. It's normal for your pump to require more energy (higher RPM) when the cleaner is attached and doing it's job.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2016
    Lakeside
    4
    Thanks .. it seems like I have to run that pump way too high to get the vacuum to move. If I lower the pump speed and adjust the valve then the skimmer sufffers and the later lever drops in the pump basket but doesnt lose prime. So... What is the better option. run the pump harder or adjust the valve so I am getting more suction from the vacuum line ?
    needsajet's Avatar
    Jan 2016
    4,261
    With a variable speed pump, I would leave the flow adjustment valve set to maximum flow, or remove it, and then find the best pump speed. Then when you use the vacuum, always use that same pump speed. If you're plugging it into the skimmer, it's common for the skimmer not to skim as well when the vacuum is connected. When you're done vacuuming, removed the vacuum and skimming will go back to normal.
    When you get a chance, please enter your pool information as a signature. Click the link in my signature for instructions in: Read before posting. This will help you get the best advice possible from TFP
