Thread: Confused by free/ combined chlorine
    Jul 2016
    SHELBYVILLE, Tennessee
    2
    I'm a new pool owner and am using the taylor2006 test kit. My numbers are: free chlorine 3.2ppm, combined chlorine 0.2, 7.4 alkalinity 90ppm cya40ppm.
    I'm clueless as to what the chlorine level should be but thought the free should be 0 not combined. Could someone please let me know. Thank you!
    Above ground vinyl liner,18x54 , 1.5hp jacuzzi brand sand filter/pump. Not sure on gallons (7600?) Built new June 2016. Taylor 2006 test kit.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Re: Confused by free/ combined chlorine
    Welcome to TFP! Glad you found us.
    You should give the following link a thorough reading. It will help you to understand that your FC level needed varies based on your CYA level.
    abc-of-pool-water-chemistry
    There is a link to an FC / CYA chart on that page which is a cornerstone concept.
    Please ask questions after reading through the information.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2014
    15,103
    Also, judging by your FC results, you're using the Taylor 25ml sample size right? Instead, try the 10 ml sample:
    10ml water sample, one heaping scoop of powder, multiply drop count by 0.5 (basically divide by 2)
    Example: Total # of drops until clear was 12 = FC of 6. Should save you on some reagents.
    Jul 2016
    2
    Thanks very much for that tip! So thankful for this site going to read some ��
    Aug 2014
    Northern IL
    4,615
    Let us know if you need any more clarification!
    Just in case you missed the link in the reading above, here it is straight out:
    Pool School - Chlorine / CYA Chart
