Thanks for the tips on the calculator and swg..
I was able to retest some things..
Yesterday the pool was still visibly ok, clear mostly, no slime on the walls, no green etc..
Today however things got worse.. clearly it was in need of the chlorine/bleach.. i ran some measurements using the tf100.. cya is at zero (black dot never disappeared).. FC was at zero.
Prior to doing anything i checked the sand filter.. i forgot to check the glass tube for dirt/sand in it.. i had ignored it not noticing it was probably filled with dirt/brown.. but i went ahead and did a backflush.. maybe 45 seconds or so on the intex sand pump (2800 gal/hr).. i waited till the brown water became clearer then did a rinse for maybe 30 seconds.. at this point i remembered i was to check the glass tube.. it still has a slight amount of debris in it, not that much. The pressure gauge had never got to the orange level even before this.. levels were the same before and after.. however.. the return valve was spewing out at a normal rate, visible now, more suction on the intakes too (was barely any).. it had been about 2.5 weeks since setting up the pool, where i started with one 3" tab in the filter basket initially, then when it vanished i put 2 in the chlorine floater till they were 25% gone and installed the swg and had only ran it for 4 hours to date..
Clearly out of chlorine, my fault for not keeping up with the tests..
At this point it was too late to run and get bleach.. so i opted to use the poolife 78% ca hypo i had on hand.. bag says use 9-16oz (16oz = full bag) for 10,000 gallon.. i decided to dump the whole thing in.
Went out about 2 hours later.. wall still slimy (but i'm guessing that could take a day or more to clear and/or more bleach/shock)..
Ran the tests. FC took 36 drops.. FC is now reading 18 (the intex test strip i have on hand seems to show 10, it also shows alk at around or below 40 and maybe ph at 6.2, acidic)..
I think at this point i need CYA, and to boost the ph (baking soda?), saturday i have a better salt tester coming.. i think it will show normal levels (kids in pool said pool seemed salty) and probably at that point ill run the sand filter and swg for 6 hours a day at the same time.
Either way i'm learning how to use the tf100 kit.. liking its better accuracy and its not too hard to do.
