Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Intex saltwater water system salt ppm woes and general Rust prevention questions?
    Jun 2016
    Pittsburgh, pa
    367
    I was about to install the saltwater system in my pool, however i have been reading a lot of bad stories both in general and with the saltwater system about rust. Is it a good idea to do this use the saltwater system or is there some preparation to avoid the rust (and once the pools already up is there a way to prevent rust) in my case it's already up. I read something about putting special tape on the metal may help
    Any thoughts?
    Thanks
    Jun 2016
    Pittsburgh, pa
    367
    Re: Intex saltwater water system + ultra frame 18 by 52 bad for rust? Prevention?
    I did see some are also using something called fluid film.. not sure how long this lasts, but maybe with this + saltwater system i'm good to go.. (year or bi-yearly coat)
    I read something on here about grounding with an 8 foot copper rod, but i'm unsure on what this entails ( i dont think its related to rusting either).
    Jun 2015
    Stockholm, Sweden
    250
    Where did you read this? There is no reason to think that a SWG would cause any more rust than other methods of chlorinating the pool.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2016
    Celina, TX
    34
    Quote Originally Posted by Mickelin View Post
    Salt is very caustic and will accelerate rusting. Look at the car bodies of northern state cars.
    Bill (aka CR172) 16' x 48" (5300 gal) Intex Ultra Frame AGP, 2150 GPH 14" Intex sand filter/pump, Intex CS7110 SWG, Intex under water magnetic pool light, Hayward SP1091LX skimmer, Confer Roll guard safety ladder, TF-100 test kit w/ AquaCheck salt test strips.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    It is true, the salt content in the water will make things rust faster, it's not the SWG itself that does it. That said, clean and paint any bare (or poorly painted) metal with a rust inhibitor. Keep an eye on areas that could be a problem. Hopefully Intex fixed the issues they had in the past. I wouldn't bother with anything else but I dunno about the ground rod for that type pf pool. In my area it is code to have a ground wire around the pool and maybe to ground the pool too? Sorry, memory is foggy on this seeing it's been awhile since I installed our pool. I do get more corrosion with the SWG but it is worth it.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jun 2015
    Stockholm, Sweden
    250
    Again, I ask where did you read that a SWG caused rust in an Intex pool? I have seen no evidence of that in this forum, only a lot of speculation and second hand rumors. The water in a SWG pool is not salty (i.e. not like seawater). You cant even taste it, the concentration is so low. It is the chlorine that causes rust, not the very limited amount of salt. The Intex pool will rust just as much without salt in the water.
    Jun 2016
    Pittsburgh, pa
    367
    I saw varied posts on here related to rust + SWG.. i agree though, hard to say without a control, whether or not the two are definitely connected..
    So that said.. shift focus to rust prevention in general..
    Like i said above.. my pool is already up.. so i guess all i can do for now is to use the Fluid Spray to coat the existing and visible bars.. and also, maybe prior or after or both, i was going to use this Rescue clear tape around the joints.. hopefully this is good enough for now since i cant take them apart.
    Aug 2013
    Otsego, MN
    79
    Something else to keep in mind is that if you are chlorinating with bleach, you have salt water in your pool already. A byproduct of adding bleach (or any liquid chlorine product) to your pool is salt.
    Before I ever added salt this year for my new SWG system, I tested my water for salt. I had previously only maintained it with bleach. I already had 800ppm of salt in the pool. And I had filled over half the pool with fresh water this spring.
    If you've been maintaining with bleach for some time and haven't had significant water exchange, your level may already be significantly higher than that.
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    Jun 2016
    Pittsburgh, pa
    367
    Quote Originally Posted by 911medic View Post
    I havent hooked up the SWG yet.. nor poured in the 4.5 bags of salt.. prior to now (over about 2 weeks), i've only used about 3.5 of the 3" HTC style chloronating tabs in a floater (ph around 7.2).. my real test kit isnt here yet.. i ordered salt test strips too.. are you saying i should maybe NOT add all 4.5 bags until i check the PPM? if its already up a little maybe 1 bag less etc?
    I'm about to pour in 4.5 of this: Shop Diamond Crystal 40-lbs Salt Solar Crystals at Lowes.com
    Someone else said they had used these before with no issues.
    Jun 2016
    Celina, TX
    34
    Quote Originally Posted by theskyisthelimit99 View Post
    From experience, bring the salt level up slowly. I added 120lbs of salt per the instructions, (actually the instructions read to use 125lbs.), now I have a hi salt error and need to drain water. One thing about the Intex SWG's is when/if you get an error code, it doesn't generate any chlorine. I've been adding a little at at time until I can get things right.
    Jun 2016
    Pittsburgh, pa
    367
    Quote Originally Posted by CR172 View Post
    Ah nice thanks for the tip.. i suppose maybe i should add 40lbs at a time, check the readout and move on if needed.
    Jun 2016
    Celina, TX
    34
    You say you have 4 1/2 bags. I'd probably do 3 then check. It takes ~24 hrs for the salt to dissolve and get circulated and thoroughly mixed. Ours didn't throw the error for several days.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Yep, go slow and give it time to mix or you may overshoot.
    Mike
    Jun 2016
    Pittsburgh, pa
    367
    Quote Originally Posted by MikeInNH View Post
    Ok cool.. is there any harm in using the water/swimming in the meantime, so long as the levels are generally in check/water is clear, after adding the salt (say 12 hours later maybe)?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Last time I pour salt in my swimming pool, i was inside my pool, salt is the safest chemical that you can add at the pool
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2016
    Pittsburgh, pa
    367
    btw, the fluid film spray material may work well (time will tell), but its very messy (doesnt dry, leaves sticky residue which attracts bugs), probably best kept at the hinges and or where you see bare metal and no paint.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    As mentioned, swim to your hearts content as long as your chlorine levels are good. The ocean has way more salt then you will see in the pool. Some say it's good to vac the pool before adding more salt if you are close because sometimes it hasn't completely blended with the water. Vacuuming helps move the water from places that are slow moving.
    Mike
    Jun 2016
    Pittsburgh, pa
    367
    I'm a little confused.. for testing the salt i was using the Aquacheck strips scooping some water in a cup then testing.
    Initial test, the bleach line was well below the very smallest reading possible.. basically nill.. so i added 2 of the 4.5 bags that should be required.. tested again a few days later.. having run the swg system after waiting the 24 hours for a few days.. that test of salt then showed about 0.8 or so on the scale..
    Now i decided to add the rest.. 2.5 more bags.. ran the regular sand filter for 24, turned off the swg.. tested the salt now.. its around 2.1 which is something around 500 ppm.. i'm puzzled.. am i doing something wrong.. should i still be turning on the SWG for 4 hours per the instructions at this point.. or do i really need to add more salt bags.. by my count i'd almost end up needing 8 bags if this trend were accurate, double the lb value in the instructions.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Something doesn't seem right. The test strips can be bad if old. You also need to let it sit in the water for a bit. I wouldn't run the SWG until you get the salt number correct or it could harm the unit although they usually tell you low salt when it is low in ppm's.
    How much water does your pool hold? If 8000 then 200 total pounds to get to 3000PPM from 0. You may just need to run the filter more to get it mixed better. No need to try and conserve the test strips, they probably won't be good next year so keep testing by getting water from different areas and depths.
    Mike
  20. Back To Top    #20
    Jun 2016
    Pittsburgh, pa
    367
    This pool holds 6900 or so i think.. i think the value in the manual said around 170lbs.. i forget.. when i tested i just took a cup and scooped off the top (both times).. i had just got those strips off amazon, maybe i should order the drop kit for salt testing instead, yeah its $26 but maybe the numbers would come out differently.. the swg unit never said low or high salt either when i did run it.
    I also used the 100 test kit and tested the chlorine.. its showing "clear", i guess none? (eek).. but the ph is 7.2.. perhaps this is also a factor.
