Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: cant hold chlorine
    Jun 2016
    Feasterville/PA
    53
    cant hold chlorine
    I bought my house 4 yrs. ago that has an inground pool. I am a novice pool owner and did not have any problems the first two years. Last yr when i opened it, it did not hold chlorine when I first opened it. I had to triple shock it twice and everything was fine. I had the same problem this yr. and the pool still will not hold chlorine. I usually did whatever the pool store told me to do, but I have spent more money this yr. than the past three years combined. The last time I was there they told me I have nitrates, and that's why my pool is not holding chlorine. I found this website and it has really opened my eyes. I was looking around on the website and found some interesting information. I finally bought my own test kit, but am a little nervous using it. I am at my wits end trying to keep chlorine in this pool and am also tired of shelling out a ton of money and nothing is happening. My pool is a little cloudy right now, when I got the water tested here were the results:
    FC-0
    TA-80
    PH-8.0
    Hardness-300
    Nitrates-15
    This is the first time my Ph was high. I need help. I need a step by step process of what I need to do. Thanks in advance for your help.
    16x32 19000 gal Sun most of day Hayward 1.0 HP D.E. Filter Vinyl liner Taylor K-2006 Test Kit Feasterville, PA
    30,410
    Re: Can't hold chlorine
    Welcome to the forum.
    Tell us the brand and model # of the kit....we'll get started helping you clear your pool.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    Re: cant hold chlorine
    Welcome to TFP! Glad to have you here.
    I'll give you two links...
    One for the basics of chemistry that we follow here:
    abc-of-pool-water-chemistry
    And one for the process you need to follow now since your pool is cloudy and you have no FC.
    SLAM - shock level and maintain
    What we practice here is in conflict with Pool Store advice. Its about understanding what your pool needs and what chemical additions will do to your pool. You will need to follow our recommendations or those of the Pool Store, following both won't work. That also means not letting them test your water. Trust your results.
    Please post your results in the following format for us to begin:
    FC
    pH
    TA
    CH
    CYA
    If you are all in with our methods, you will be chlorinating with plain old bleach going forward. Testing and dosing daily. And your pool will be Trouble Free.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2016
    Phoenix, AZ
    8
    Did you test for CYA?
    10K gal, pebble tec, 2.5 HP pump, 600 sqft DE filter (Hayward DE6020), Chlorinated, Hayward Navigator
    TF-100 Test Kit
    Phoenix, AZ
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    We need to know your CYA level.
    Jun 2016
    Feasterville/PA
    53
    My Cya was 40
    Test kit-Taylor k-2006
    DFW, TX
    24,468
    With CYA at 40 your FC needs to be above 3 at all times, FC/CYA Chart. When FC drops below 3 the pool is unsanitary, algae, bacteria, viruses and pathogens can grow and the there is increased risk of person to person disease transmission.
    Often when there is difficulty maintaining chlorine it is because algae is growing in the pool. The easiest way to determine if there is algae growing in the pool is to do an Overnight Chlorine Loss Test. If it doesn't pass then kill the algae using this process, SLAM.
    Jun 2016
    Feasterville/PA
    53
    If I have a reading of 0 for chlorine before I do test, what should I put in and how much?
    DFW, TX
    24,468
    Use Poolmath to calculate your doses. Enter your test results in Now, pool gallons, pool type, etc and it will calculate your dose to get to target. You can verify targets here, Pool School - Recommended Levels. If the number is in range make target equal now so it doesn't tell you to add something. More here on pool chems, Pool School - Recommended Pool Chemicals
    If you like detailed instructions they are here, Pool School - PoolMath
    Jun 2016
    Feasterville/PA
    53
    So I added the correct amount of chlorine to do the OCLT that should take me from 0 to 5 FC. I let it circulate into the pool and then tested for FC. It only showed up as 1.4. I definitely have the right pool measurements and depth. What am I doing wrong?
    DFW, TX
    24,468
    Probably nothing. There is probably some yuck in there using it up. Aim for 10 ppm this time.
    Jun 2016
    Feasterville/PA
    53
    Tested water last night and FC was 10.2. Tested water this morning and FC was 5. Is my next step slamming, and if it is, can I Slam in the rain? We are supposed to get some today and tomorrow.
    May 2015
    Land O Lakes, FL
    527
    Time for SLAM. Rain does not matter.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2016
    Feasterville/PA
    53
    Just so I understand this. After putting in the initial dose of bleach, should I test and make sure I am at shock level? After that, how many times do you recommend I test throughout the day to make sure I stay at that level?
    Jun 2014
    Rogers, AR
    424
    Quote Originally Posted by Jluke120 View Post
    As much as you can, ideally every hour until you hold chlorine longer. Leave the pump running 24/7, check your pressure and brush. Brushing is really important brush, brush, brush.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Jun 2014
    15,037
    With your CYA of 40, you'll want to increase FC to 16 with regular bleach. Let it mix for about 10 minutes then check again to see if it's holding at 16. You may need to do it that way (if you can every 10-15 minutes) for the first 2-3 times just to make sure the FC is holding its own because when you first start a SLAM the FC might want to drop quickly. Eventually you'll be able to back-off of the testing so frequently. Once the FC begins to hold better, you might be able to just test mid-morning, lunch, mid-afternoon, then evening. You'll see a pattern that works for you based on FC drop. Good luck!
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    You want to test and dose back to shock level as often as is feasible for you. If you have to work, test/dose before work, when you get home and before bed. If you are able to go home at lunch and do it again, that's a bonus. The more often you can get the FC level back to shock, the faster the SLAM will go. But everyone has time constraints, it will still work testing/dosing less often. Good luck and keep us updated!
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jun 2016
    Feasterville/PA
    53
    Thanks for the info. I will keep you posted.
    Jun 2016
    Feasterville/PA
    53
    Two questions. Should I have my chlorinator open all the way during this process? Is it ok to be over the shock total of 16?
  20. Back To Top    #20
    May 2015
    Land O Lakes, FL
    527
    It is usually recommended to your chlorinator/SWG so that you don't have other variables and you will know right right dosage.
    Matt
