Thread: High levels of chlorine
    Jul 2016
    Istanbul
    1
    Chlorine smell increased a lot and I decided to check Chlorine levels with a 2 way tester. My neighbour has been taking care of the pool.
    Pool dimensions are 32 x 18 x 6 feet.
    My neihbour has been pouring 1 lb of chlorine every day.
    According to test kit, chlorine color should be yellow and a value of 1.0 to 1.5 is regarded as "ideal". In my tests Chlorine color turned into RED. Stopped pouring chlorine for 6 days and tester color turned into dark yellow (was red 6 days ago). Still not at the desired level.
    At the end of 6 days PH value is 7.0 to 7.2
    I think my neighbour overuses chlorine. It was smelling a lot of chlorine, even the swimming suits smell.
    1) how often should I pour chlorine? Is there a shedule or do I monitor chlorine level and pour accordingly?
    2) which test kit is a good kit?
    Cheers
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: High levels of chlorine
    What you are smelling is not chlorine---it is chloramines---------the byproduct of things being killed and disinfected, but not fully burned off. This is called CC---combined chloramines. BAD stuff. I recommend you get one of the TF100 test kits and follow our SLAM procedure. See the chlorine/CYA chart in Pool School. Welcome.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Are you in Istanbul Turkey? If so, try to find a Taylor K-2006 test kit. Or another drop based test kit that has the following tests.
    FC - Free Chlorine, need FAS/DPD chlorine test
    CC - Combined Chlorine
    pH
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
