Results 1 to 11 of 11
Thread: Help with the next step
    T&CFontaine's Avatar
    Jul 2016
    Grand Forks, ND
    6
    Question Help with the next step
    Hello, We are new to posting, but not new to creeping and reading TFP's advice. I hope someone can help.
    We had an algae outbreak a couple of weeks ago and still trying to get back to beautiful water. I used the SLAM method and it worked...only to have the algae problem come back. We did a complete test using our kit and found that our CYA had crept up to 80-90. We are trying to convert to the BBB method and have been avoiding draining and refilling since last summer's season. Knowing that we couldn't avoid it any longer, we drained 50% of the pool last night and used the city water hydrant to fill it back up. The water is pretty clear (not crystal...yet) I can see the bottom of the deep end just fine. We added 2 gallons of liquid chlorine to bring it up to shock and went to bed. This morning the chlorine tested at 11, we put another gallon of chlorine in it. I went out and ran all of the tests this afternoon:
    FC:12.5
    CC: 0.5
    pH: 7.6
    TA: 60
    CH: 120
    CYA: 40
    I added another gallon of chlorine to it and will test it again tonight. I am wondering if we need to worry about our TA and CH? They are both on the low end.
    Thanks!
    Pool: IG 16x32, 22K gallons, vinyl liner, built in 2009
    Equipment: Hayward super pump model #S210S, Hayward Pro series sand filter model # C4812N134B1,
    Taylor K-2006 test kit, Dolphin Nautilus cleaner
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Help with the next step
    Just to be clear, you are testing and adding enough to get you to your SLAM target, right? Pool School - Chlorine / CYA Chart
    Not just blindly adding 1 or 2 gallons .... randomly. I understand not wanting to measure say 13oz, but at least go by 1/3 bottle increments.
    To answer your question, no you don't need to worry about either of those until your SLAM is complete.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,109
    TA is actually fine many run that low CH not a problem for a Vinyl pool so you are good there. Since your last SLAM did not stick I would re read just to be sure you are following all the steps, one of the main reasons for a SLAM not working, is not being diligent about the Maintain step. The other reason could be some hidden algae somewhere like light niche.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2016
    Grand Forks, ND
    6
    Yes, we are testing and adding. I have the chlorine/cya chart printed out and next to the test kit. Thanks for double checking though!
    I am certain that we did not maintain. Our CYA was up high and we couldn't keep enough chlorine in the thing. We made a few other mistakes in trying to hurry the process along as well...lesson learned. We will be taking it slowly and staying out of the pool store.
    Thanks for the answer!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,279
    It's really good to hear that you figured out the importance of a partial drain through your research here. Sounds like you have the water chemistry well in hand as well. Good stuff!
    Sounds like the MMMaintain part, but could also be brushing which scalps the biofilm over the algae so they fully taste the active chlorine.
    There's other weird reasons for a SLAM to be difficult - already mentioned is hiding places. Really look for those. Anything that can be taken out and scrubbed should be done, back of the skimmer weir(s), wedding cake steps, under ladder steps, etc. can all be algae farms because of poor circulation.
    Also any outside sources like runoff water, dog jumping in, duck poo, etc. can cause trouble.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Aug 2014
    Northern IL
    4,615
    You are maintaining an FC level of 16, correct?
    Check your light niches if you have incandescent lights, steps, behind the weirs in your skimmer, everywhere for hidden spots. Even if you don't see visible algae, scrub them. A toothbrush works wonders in small areas.
    Jul 2016
    Grand Forks, ND
    6
    Quote Originally Posted by needsajet View Post
    I spent this morning scrubbing away! The dolphin is in now. We do have a new pup that loves the pool...that is something that has changed since the previous years. Are there any precautions we should be taking as far as balancing goes? We are working on training him to stay out on our command, but that is proving to be harder than we thought. Thanks!
    Jul 2016
    Grand Forks, ND
    6
    Quote Originally Posted by MarianParoo View Post
    Yes, I am maintaining a FC of 16. We had a cloudy day here yesterday so that helped a bit. Added chlorine before bed and it was at 12.5 this morning. I added more to get it back to 16 and will check it again now during lunch.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    The best way to speed up a SLAM is to test as often as possibly, even hourly, and bring that FC up to SLAM level again and again as the chlorine is depleted killing algae. Those are the SLAMs that go the fastest. If you're only testing a couple times a day it will drag it out.
    Jul 2016
    Grand Forks, ND
    6
    I am not able to test that often today, but will be able to keep on top of it since the weekend is right around the corner!
    Aug 2014
    Northern IL
    4,615
    Perfect!
