Thread: white spots in blue plaster pool
    Jul 2012
    Mountain House, CA
    62
    Unhappy white spots in blue plaster pool
    My pool is about 18 months old now, and is forming white spots that are concerning me.
    I have done some research on this, but there seem to be several possible causes so I'm looking for more experienced advice on how to combat this issue before it gets worse, and hopefully reverse it.
    10k gal IG w/ salt system, spa, gas heater, and auto cover.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: white spots in blue plaster pool
    Add your location, city AND state to your profile so it shows up over there <----. Sorry for all caps but an amazing number of people only add their city and not their state, which often doesn't help.
    Update your signature to show what type of pool finish you have and when it was completed. ie, pebbetec, quartscapes, plaster, etc
    Give us the last few sets of test results and how you got them.
    More info here on what we need to better help you, Pool School - Read This Before You Post
    Jul 2012
    Mountain House, CA
    62
    It's a plaster pool with a saltwater generator.
    pH 7.2
    Cl 1.5 ppm
    (these two change every few days, I add acid and bleach regularly to supplement the SWG during hot periods or extra swimmer load)
    TA 70
    CH is always a strange test for me, it never "turns blue" but the precipitation gets a bit blueish around 750
    CYA ~20
    TF-100 test kit
    I have an autocover if it matters.
    DFW, TX
    24,497
    More here on the CH test, Pool School - Extended Test Kit Directions
    If your pH spends a fair amount of time above 7.8 then it could be calcium scale. Are the spots rough-and-tumble raised? More here, Pool School - Calcium Scaling
    There are a couple of other possibilities here, Diagnosing Pool Plaster Problems
    Your CYA is lower than we recommend for a saltwater pool. More here, Pool School - Water Balance for SWGs
