Thread: How much FC is "too much" ?
    May 2008
    southern New Hampshire
    41
    This year I have the mindset that I am going to maintain as high a level of FC's so as to not cause harm to my swimmer guests. Right now my FC is 5, and my kids swam for severall hours this past memorial day. I can smell "chlorine", near the pool, but my kids had no problems at all. No red eye, or irritation. Is FC of 5 too high? OK ? how about FC of 6? Thanks!
    Rich
    "To be old and wise, you must have been young and stupid"
    18X33 Aquasphere buttress AG pool
    Pentair SD60 sand filter/1 hp pump/ Pool Frog
    Polaris 65 super turtle
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: How much FC is "too much" ?
    it depends on your cya. see chart:
    pool-school/chlorine_cya_chart_shock
    and if it's a bad smell it may be cc's which are bad. do you have a test kit? can you test for cc's? your other numbers would be helpful also.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Chlorine smell is almost always from elevated CC's. Ideally you want your CC to read 0, anything over .5 you should shock the pool. As stated above, your appropriate FC level is dictated by your CYA level.
    If you don't have a good test kit, you should order one of the recommended kits. Read the article in Pool School that compares them.
    May 2008
    41
    Quote Originally Posted by frustratedpoolmom
    I have a TF100 kit , and my CYA is 50
    With CYA at 50, FC between 4 and 8 is completely normal and I am willing to swim at FC levels up to 16. Many public pools run at much higher effective chlorine levels, because they don't use any CYA.
    May 2008
    41
    OK great , Thank you !
