Results 1 to 12 of 12
Thread: Second MA Shock of Season
    Aug 2013
    Dallas, TX
    78
    I'm trying this again after last month's didn't take. Last time, I was gone for a few hours and the FC dropped quite a bit while I was away, so this time, I'm staying home and checking FC once an hour. I did a regular SLAM last night, water was clear (has been the whole time), CC is 0 (also has been the whole time), and passed OCLT this morning. Brushed the whole pool yesterday and again this morning. PoolMath says my MA shock level is 19 ppm. I put in enough bleach to get there this morning, checked FC an hour later and hadn't dropped at all. Checked it again an hour later and FC had dropped to 13 ppm (pool was in almost full sun by that time). Added more bleach to get back up to 19 and am about to check it again to see how it's holding.
    I'm wondering if I need to aim higher than 19 to give it room to drop if I'm losing 6 ppm in just an hour.
    23,000 gal. IG gunite pool, DE filter, elevated spa with spillover, Polaris 280 cleaner
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Second MA Shock of Season
    Can you post a full test please
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2013
    Dallas, TX
    78
    Sure. TF-100 results are as follows:
    FC 21 (checked just after my first post)
    CYA 20 (was a bit closer to 20 than 30. Last time I checked, it was 30, so that's what I was using in PoolMath)
    TA 90
    CH 500
    CC 0
    pH 7.5 (checked last night before starting regular SLAM)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Is there mustard algae on the walls? Can you post a picture? Just trying to determine why you are SLAMming.
    Aug 2013
    Dallas, TX
    78
    Yes, we've had it on the walls in the areas that are in shade for even just a portion of the day. I can't post a photo because I've already brushed everything. I thought I had gotten rid of it last month, but it showed up again. We brushed everything that time, too, including inside the light niches, so the only thing that I figured I had done wrong was letting the FC level drop below MA shock level for a few hours while I was away.
    Should I try to keep FC higher than my MA shock level during this SLAM?
    I've also read somewhere that keeping FC above target level but lower than SLAM level on a regular basis can help keep MA from getting established. Is this true?
    Jun 2015
    Jackson, NJ
    123
    I'm certainly running my chlorine above the minimum target now. I'm going to follow this chart: http://www.troublefreepool.com/threa...rine-CYA-Chart
    I'm going to run the mustard algae minimum and some PolyQuat 60 in the hopes I can get through the season w/o a recurrence.
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
    Aug 2013
    Dallas, TX
    78
    My target range based on CYA of 30 is 2-6 according to PoolMath. I've been keeping it at about 4-5 and adjusting accordingly each day. Should I be keeping it at 6 or higher on a regular basis?
    Jun 2015
    Jackson, NJ
    123
    All I know is mustard is a pain and more resilient than the other algae types so I'm going to run it right under the MA level on the chart (I have a SWG so I can go a smidge lower than a manually dosed pool). So for my CYA 70 I'm shooting for 9-10.
    TF-100 Test Kit
    Aug 2013
    Dallas, TX
    78
    I'm still in the middle of the MA shock, continuing to check FC each hour. I'm finding that I'm losing between 1 and 3 ppm each hour, and I continue to add bleach as needed to get it back up to 19. I'm still wondering if I need to aim higher than 19 with each addition of bleach in order to give it room to drop a couple of ppm and still maintain MA shock level, or is that just wasting bleach at that point?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    When you are doing a mustard algae shock go ahead and throw all the pool nets, vacuums, brushes, toys, floats, hoses, anything that has regular contact with the pool water in there and let them soak at MA levels overnight. Hose them down when you take them out and let them air dry. Wash and dry swimsuits
    Bleach drops exponentially and not linearly. Higher FC levels will see a larger drop over the course of the day. The best thing is to bump to MA levels before you leave and bump it again as soon as you can.
    Love TFP? Become a
    TFP Supporter!
    Aug 2013
    Dallas, TX
    78
    Ok, that's what I've been doing today, so it sounds like I'm on the right track. I washed swimsuits, but they have to be dried in the dryer? I usually hang them up in the house to air dry, so if I need to dry them in the dryer, please confirm.
    My daughter has a Puddle Jumper, which is a fabric-covered floatation device similar to a life vest. Can I wipe this down with Clorox Cleanup spray? It will only float in the water front-side up, so I can't soak all surfaces of it in the shocked pool water. I have my net and brushes soaking already.
    Jul 2009
    Houston, Texas
    9,429
    That will probably be ok for the puddle jumper. I think the heat is supposed to help kill the algae spores in the swimsuits, so I would run them through the dryer.
    Love TFP? Become a
    TFP Supporter!
