Thread: How much flow through a 2 speed pump?
    Suppose I can move 50gpm at the high speed setting. Will I move 25gpm on the low speed setting?
    16 x 32 18,000 gal IG vinyl pool. 1.5HP SuperFlo VS pump. Hayward C4030 425 sq ft cartridge filter. Hotspot FPH heat reclamation pool heater.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: How much flow through a 2 speed pump?
    Yes.
    Mark
