Results 1 to 11 of 11
Thread: Heads up, Pentair Intelliflo 2VST doesn't talk to Solartouch controllers
    Aug 2015
    Orlando
    116
    I just bought VS pump the Intelliflo 2 vst, to match up in my system. Everything I read says it can talk to Solartouch with communications cable (included with pump). Seems not quite true, my Solartouch is only 10 months old, but apparently the 2VST is running different software than the Intelliflo series of pumps, and as such requires a software/firmware upgrade.
    Evidently v2.2 fixes the issues, and my controller is only v2. Took several hours and several calls to Pentair support by installer to confirm issue.
    High 5 to Pentair for owning up to the issue, and promising to send out a tech in the next day or two to 'flash' my solartouch controller.
    Will update with final results.
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Heads up, Pentair Intelliflo 2VST doesn't talk to Solartouch controllers
    Thanks! That is good to know. The Intelliflo2 is the new model of Intelliflo that replaces the "good old" original 011018 that everyone knows and loves. It has been out maybe 6 to 9 months I guess. Best I can tell it is exactly the same except adds a rotatable control pad. And non-backwards compatible firmware! Now to see if it works with Easytouch and Intellitouch.
    Aug 2015
    Orlando
    116
    Quote Originally Posted by flipr View Post
    Pentair came out today, and had 'trouble' flashing the solartouch, so they are sending a new controller board at no cost to dealer. They are farther than they were, solartouch in demand ramps up speed of pump, but evidently it never shuts off when solartouch turns off solar need.
    Another day of 'wait and see', but good customer service so far!
    Phil
    Jan 2012
    340
    Quote Originally Posted by pooldv View Post
    I have installed them on Easytouch systems that were designed to run the original VS-3050 with no issues other than limited functionality. Can only program 4 speeds and not feature circuits for different speeds. Must use aux circuits for different speeds.
    Have not done any on Intellitouch. Flashing those things seems to work about .0000001% of the time though.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    DFW, TX
    24,450
    LOL! That is a pretty low success rate. But it is a higher success rate than the OP has experienced so far.
    Aug 2015
    Orlando
    116
    FINAL update, SUCCESS.
    Pentair sent out a new controller board for Solartouch, but it didn't have new software, so no change.
    Tech came out today and flashed new controller board, and it worked, they flashed to v2.2 software.
    Per installer and Pentair, it is working correctly. I couldn't test as it was overcast when I got home.
    Kudos to Pentair for taking control of issue, and to my installing dealer for sticking with it.
    Phil
    DFW, TX
    24,450
    Thanks for the update.
    Just in case someone from Pentair is reading this, please put a USB port on your devices and the file on your website so everyone can update their own firmware. Thanks!
    Think that will work?
    Jan 2012
    340
    I think what you meant to say is catch up with Hayward Omnilogic
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Port is in the pipeline, don't know if it will be for the end user as much as it will be for the tech though.
    Factory Warranty Station for:
    Aug 2015
    Orlando
    116
    Quote Originally Posted by Pool Clown View Post
    I was thinking the same thing when I saw the software on the Pentair site, but then looking found it required to install with special adapter.
    The way technology changes, user updateable products would be nice, but defeats the planned obsolescence side of the marketing program.
    Phil
    Aug 2016
    Encinitas
    1
    I may be having this same problem. Do you know where I find the version number of my Solartouch? I have a new Intelliflo 2 and it is not communicating with my Solartouch.
    Josh
    Mar 2018
    Jacksonville, FL
    0
    Not to resurrect an old thread, but I was able to update the Solartouch firmware myself. Pentair sells an expensive kit ($200+) that does it, but you can just buy the Pickit 3 from Amazon ($48).
    https://www.amazon.com/gp/product/B00E4WFS8Y
    Software is at MPLAB- X IDE | Microchip Technology Inc.
    (use "MPLAB IPE" to do the programming).
    Hope that helps.
