Thread: Pool Light Lens
    May 2016
    Camlachie
    8
    Pool Light Lens
    Last night I noticed that my pool light lens has broken loose from it's casing.
    I'm guessing that the screws got so corroded, that they broke.
    I haven't gone under to investigate the hardware issue yet.
    My main concern is that if the pool light lens is open, am I at risk of water getting in behind the liner?
    Or does the light housing seal the water in?
    I plan to fix this week, but was just curious.
    As for safety, this light is shut off at the breaker.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool Light Lens
    Usually the niche is sealed with the liner. The lens keeps water out of the light fixture.
