Thread: FC Test with less chemicals
    May 2012
    Allentown, PA
    219
    Is it accurate to do an FC test using 1 scoop and 5ML water sample and counting each drop of R087 as 1 ppm FC? My FC is at about 13 and it seemed to work well. Thoughts?
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: FC Test with less chemicals
    I use one rounded scoop of powder but have never tried the 5 ml of water. Have you done a back to back test with the 10ml of water and 5 ml to see if they "match"? I think the 10ml uses little enough regents I do not worry about it.
    Kim
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Keep in mind, any time you use less volume, the precision of the test is decreased.
    From Pool School - FAS-DPD Chlorine Test
    The precision of the measurement is plus or minus one drop when up to 10 drops of titrant are used, or plus or minus 10% of the final reading, when more than 10 drops of titrant are used.
    Isolated Spa - 345 Gallons
    Donldson's Avatar
    NW Ohio
    2,926
    Quote Originally Posted by JVTrain View Post
    Right, so to illustrate, if you are using the 10 ml sample your error rate will be +/- 0.5 ppm up to 5 FC, 1 ppm at 10 FC, and 2 ppm at 20 FC. If you are using the 5 ml sample then your margin of error is double that. So a reading of 13 means your FC is between 10.5 and 15.5 (rounded).
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2016
    MD
    195
    Quote Originally Posted by Donldson View Post
    Maybe I am getting huge errors and that is my issue... doesn't seem to accurate at that rate... hmmm.
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    May 2012
    Allentown, PA
    219
    Okay thanks for the input. I have been using 1 round scoop of powder and 10ML water sample, but I tried it with 5Ml and got the same results, so that is why I posted the question. Seeing that the margin of error increases I will stick with the 10ML water sample. Thank you for all the responses.
