Thread: Pentair Compool to EasyTouch Upgrade
    Jul 2016
    Raleigh
    2
    I have a Pentair compool cp3600 that has died - ordered the upgrade kit without the transformer (521107). Will I need to also order the Pentair wall mounted control panel (520549) or can I still use my old wall mounted controller used for the cp3600? Thanks
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,537
    Re: Pentair Compool to EasyTouch Upgrade
    That might be something best asked of Pentair. Hopefully you will get someone that knows when you call.
    Kim
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You do not need the indoor control panel with that upgrade as the outdoor panel has the ability to act as the indoor panel would (change settings, create programs, assign labels, etc.). You just loose the convenience of operation from inside your home, or where ever your old indoor panel was.
    Unfortunately, the old panel does not interface with the new E/T system. You can however, use the existing cable for communication between the new outdoor and indoor panel(s).
    Factory Warranty Station for:
    Jul 2016
    Raleigh
    2
    Thanks Pool Clown - that is a big help!
