Results 1 to 7 of 7
Thread: Skimmer install - while pool is empty or nearly full?
    Jun 2016
    Florida Keys, Florida
    4
    Hi everyone,
    What is the consensus? We're setting up our first pool, an Intex 12' x 24' x 52" Should we install the wide-mouth skimmer while the pool is empty, just starting to fill, or nearly full?
    Many thanks!
    Scott
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,462
    Re: Skimmer install - while pool is empty or nearly full?
    nearly full........when they put in our liner they waited until the water was just under where the return hold on the wall was before they cut the liner to put in the return and skimmer. The reasoning is that the water will pull on the liner/walls as it fills. If you cut too soon it will not be in the same spot when the water starts going in and up.
    Kim
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I second nearly full, for the same reasoning as Kim. I actually installed mine while the pool was 100% full
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jun 2016
    4
    Thank you for the responses. I'm thinking of placing the top row of screws above the blue part of the liner, to get maximum water depth. Too risky?
    philc's Avatar
    Jul 2015
    190
    I went below, but several have gone above without any ill effects.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,522
    Here's where I put mine
    I keep my water at the same depth as I did with the over the wall skimmer, right at the level of the top screws on the sides or right at the bottom of the first full blue square.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP Scott
    Please add your pools info to your signature as outlined here: Pool School - Getting Started
    Solar Blanket, Well Water, Borax Added. 68
