Results 1 to 8 of 8
Thread: CYA
    Jun 2016
    Manteo north carolina
    50
    CYA
    Last Saturday I had to add 64oz of Cya. My ph was 8.2 the cya lowered it to 7.2. Now my ph is back to 8.2, I still need to add some more cya. Do I add cya first and then work on ph?
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: CYA
    You're SWG may be causing the rapid pH bounce. If you have a high TA that will just make the bounce more rapid. Post that reading. While you are at it, might as well post all results because someone will inevitable ask for it. As for your question, I would continue to manage that pH down to the 7.4 ish as it will tend to rise it appears. You can dissolve some more CYA and manage the pH simultaneously.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2014
    15,070
    Re: CYA
    I would note that you mention using CYA to lower pH, but CYA doesn't lower pH. Not sure if you got your terms swapped as it's muriatic acid (not cyanuric acid) that lowers pH. Just wanted to be clear and not confuse anyone later who may read your post. Assuming you did indeed mean to say "muriatic" acid to power pH, you'll want to refer to the Pool School - Lower Total Alkalinity page for more details.
    Now if you truly did add "cyanuiric" acid (CYA/stabilizer), then you may now have a whole different problem.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: CYA
    Good point by TXSplash. CYA is acidic, but not enough to drop the pH that much.
    Jun 2016
    50
    Re: CYA
    My TA is 176. My cya is 50.
    No I added the cya and it lowered my ph. I have muriactic acid but I was trying to adjust cya first.
    Jun 2014
    15,070
    Re: CYA
    Okay then, you'll want to use "muriatic" acid as noted on the Pool School - Recommended Pool Chemicals page to lower pH. Take the pH all the way down to 7.0. Use aeration to raise the pH all the way up to 7.8, then hit it again with muriatic acid and repeat the process.
    In a day or two, I would suggest checking your CYA to ensure you didn't shoot that number too high.
    Good luck!
    Jun 2016
    50
    Re: CYA
    Added muriatic acid how long before I can test?
    Jun 2014
    15,070
    Re: CYA
    I'd let it mix real good for at least 30 min after adding acid then re-test.
