Thread: Retrofit bonding project
    May 2016
    Tallahassee
    71
    I have a pool that is over 40yrs old and doesn't have any kind of bonding grid. I am entertaining the idea of redoing the concrete decking to get all the settling cracks as well as the bird feet that have been in the concrete for 40 yrs now . I am going to take the project on when I redo the tiling around the pool, having the pool replastered (which it is in desperate need of, there is a chance that it is the original plaster!), and replace the coping as well, as well as install a screen around the whole pool....
    my idea for the concrete was to add between 1-2" to smooth out all the imperfections and iron out the settling cracks, and then thinset above that when I tile it (most like porcelain tile)....anyhoo, I thought about building a bonding grid into the concrete in a 3 feet circumference around the pool spaced 12" apart with 8 gauge bare copper wire and attaching it at four points to the pool....one I know will be a metal ladder that goes into the pool....the other 3 I haven't determined, suggestions welcome....
    I have an enclosed pump room that I will bond the same wire to the pump and the power center for the SWG....
    Any other thoughts or ideas on this project are welcome....right now it is in the planning phase, and probably would commence at the earliest when pool season is over ( maybe Oct - Dec) ....
    Aaron
    20k Gunite 16' x 32' , Hayward c7030 700 sq ft cartridge filter. Pentair Superflo 1hp 2sp pump, Intellichlor IC40 w/ Power Center SWG, Hayward GL-235 Solar Controller, (2) Digital GE Timers.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Retrofit bonding project
    There are many bonding threads and it is not the easiest thing to wrap your mind around but here is a new thread we did and it made sense to me
    The pool is different but the concept is exactly the same..
    bonding, ground, electrical knowledge needed
    Jan 2016
    Mesa, Az
    541
    You'd be better off with an epoxy aggregate topping instead of concrete/thinset/tile. I'd have any low spots mud-jacked prior to topping.
