Results 1 to 10 of 10
Thread: Replacing my old Pentair single speed with a Hayward SP2302VSP - question about timer
    Hi all!
    I've recently moved my pool equipment to the other side of the yard. So far I haven't had to call in a professional to help, but that may change.
    When we hooked everything back up to the new panel, everything had juice, but the motor gave a whimper and refused to move. It's about 15-20 years old, and we're going to take it a part, but I think we need a new one, and I'm looking at the SP2302VSP. It's a ~30,000 gallon pool.
    Here are some rough pictures of the new setup:
    Questions:
    1. In general, are there any compatibility worries with my whole system being Pentair, and the pump being Hayward?
    2. Currently we're using a 2 timers; one timer for the pool sweep, and one timer that controls both the motor and the Pentair Intellichlor. What becomes of this timer? Is it still needed? How tricky will the re-wiring be?
    Thanks much!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,822
    Re: Replacing my old Pentair single speed with a Hayward SP2302VSP - question about t
    There's no reason you cant use the Hayward pump it will work fine in your system, but the Pentair Superflo VS 342001 is the direct fit replacement for the pump you have and is generally a lil bit cheaper than the Hayward pump. If you do go with a VS pump both the Hayward and Pentair use an onboard electronic timer and should be wired directly to a breaker and not an external timer. Otherwise that's a nice clean project you got going on nice work.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Brand only matters when you want to install automation, then you want everything that plugs into the automation to be the same brand. My VS pump is wired to the breaker and uses the onboard timer to control pump speed and run time. My Intellichlor SWG is wired to a timeclock to turn it off and on. I have to check periodically to make sure the time is the same on pump and timer. And since I run my pump a lot more than my SWG I always make sure my SWG run time is well inside my pump run time just to be extra safe.
    You do not want to have your SWG on when the pump is off it can explode. Not kidding, it happens.
    Thank you CJ and pooldv for the replies!
    Quote Originally Posted by CJadamec View Post
    Cool. Strangely, this unit was cheaper and shipped faster on Amazon than the Pentair. I didn't realize that the Pentair was a `direct fit` with my old unit, so thanks! I may have to consider that and possibly return this Hayward (which I ordered) if it looks like too much of a project to get to fit
    Quote Originally Posted by pooldv View Post
    Great, so it looks like the SWG will still be connected to the timeclock, and I have to make sure that it's only on when the pump is on. Great to know!
    DFW, TX
    24,502
    Check prices on the 0342001 at INYO Pools and Sunplay. Both are good outfits.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,822
    There's no reason to return the Hayward pump if you've already got it on the way, you should be perfectly happy. The two pumps are almost identical, and to be honest the only reason I bought the Pentair was that I found it for like 70 dollars cheaper than the Hayward.
    Chuck-
    Jan 2012
    340
    The Superflo is not a direct replacement for the Whisperflo, so you'll be doing some plumbing either way.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    May 2016
    Tallahassee
    71
    Quote Originally Posted by greenPoolGuy View Post
    Hi all!
    Questions:
    Thanks much!
    1. No compatibility issues as previously mentioned unless you are going to automate the system with a controller, but using the same manufacturer and the same pump type makes the install A LOT easier since you can just drop a new one in vs having to redo the plumbing to the pump.
    2. I would still use your old timer to control when the VSP kicks on and off, and then use your onboard timer on the pump to control what speeds you want and for how many hours. Reason being is because you can use your timer to make sure your SWG comes on and off with it. Granted, the SWG has a flow switch that 'should' turn the SWG off if the pump isn't on, but the flow switches on the Intellichlor are notorious for going bad... Usually the problem is that they show 'no flow' when you actually have flow, but my flow switch did the opposite, meaning that it was showing 'flow' always whether there was actually flow or not, thus the SWG continued to try and make chlorine even when the pump wasn't on...and since I had the VSP wired to be 'permanently on' and was using just it's on board timer, guess what happened.....boom....the SWG blew a hole right through a 1.5" 90 on the return side because it was creating hydrogen instead of chlorine....lesson learned, don't trust the flow switch... You could also permanently wire the VSP and wire the SWG to the timer and just sync the times between the two, but one power outage could throw those off and then your back to relying on the flow switch again. My system is now wired with a couple of relays where no matter what happens, if the pump doesn't get power, the SWG doesn't get power, and then uses the flow switch as a fail safe should the pump go out and the SWG still get power... Could the pump go out AND the flow switch go bad at the same time? Yes. But the chances are extremely small of that happening...
    20k Gunite 16' x 32' , Hayward c7030 700 sq ft cartridge filter. Pentair Superflo 1hp 2sp pump, Intellichlor IC40 w/ Power Center SWG, Hayward GL-235 Solar Controller, (2) Digital GE Timers.
    Jan 2012
    340
    Wire the pump to the line side of the timer and let the pump run from the onboard controller like it was designed. Keep the SWG on the load some of the timer and time it to turn on 30 minutes after the pump and off 30 minutes before the pump. This will help to avoid any issues cause by one of the timers being slow/fast or short power outages.
    DFW, TX
    24,502
    That is how my pump and swg are wired. The main thing I have to watch out for is power outages. The pump retains the time and my mechanical timer does NOT.
