Thread: Hardness Help Needed
    jdomke1's Avatar
    Feb 2016
    Manteca, CA
    90
    I've been testing my water for weeks and noticing my hardness keeps rising. It's gone from 450 to 600 to 800 today. Looking around I noticed someone recommended testing your source water which I did. I got 0 for hardness. Lost and confused about what to do I turn to this board.
    28,000 in ground gunite pool and spa
    Pentair EasyTouch 8
    Pentair Salt Water Generator
    System 3 Filter
    Max Therm Heater 400,000 btu
    Jan 2012
    'burbs of Augusta, Georgia
    7,256
    Re: Hardness Help Needed
    Did you by chance test tap water from a water softener? It would be near unheard of otherwise to have *no calcium* in water.
    Folks in the west traditionally have very hard water requiring them to manage their pool carefully to avoid scale problems.
    jdomke1's Avatar
    Feb 2016
    Manteca, CA
    90
    Quote Originally Posted by YippeeSkippy View Post
    We don't have a water softener or any filtration on the tap I used. We had a water softener that went crazy making buzzing noises so I shut it off and bypassed it.
    Pentair EasyTouch 8
    System 3 Filter
    Jan 2012
    7,256
    Hmmm... can you please repeat that CH test again... going very slowly and reading the instructions as you go? I just have to assume testing error when a CH is zero.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    More detailed instructions here
    Pool School - Extended Test Kit Directions
